Old 07-16-2007, 03:15 PM
AZDEN is on a distinguished road
Used pulse generator pendants or schematics?
Hi All,
Does anyone know where to acquire a used pendant or the schematic to build one. I have one axis to control and would like to avoid the cost of buying a new one.
Thanks.
Old 07-16-2007, 03:38 PM
NC Cams is on a distinguished road
Koyo makes a pulse code generator that gives speed and direction output pulses. They should be able to provide a schematic to simplify your task
Old 07-16-2007, 04:18 PM
Al_The_Man's Avatar
A couple of cheap ways is to either pick up a used PWG on on ebay, the attached is ones I put together, I get a local engraver to make the lamacoid panel.
Or you can use a 100p/turn encoder, but you would have to make the indent mechanism, if you want that feature.
Old 07-16-2007, 09:26 PM
Red Lion has bi-directional counters that could be used for DIY MPG.
Pretty sure they put out quadrature output. A simple gear with a detent arrangement could give you a tactile feedback.
Old 07-17-2007, 08:01 AM
I'll look into these suggestions. Thanks everyone.
EMC with what g-code generator? randyf1965 LinuxCNC (formerly EMC2) 10 09-18-2011 10:00 AM
Pulse generator / controller boards for EMC.. which one? ewest LinuxCNC (formerly EMC2) 3 04-23-2007 05:53 PM
Unfit Pulse Of Pulse Coder Alarm Crashmaster Machine Problems, Solutions , Wireless DNC, serial port 2 04-23-2007 09:55 AM
USB Pulse Generator support in EMC??? acondit LinuxCNC (formerly EMC2) 4 01-15-2007 06:42 PM
Manual Pulse generator? phantomcow2 General Electronics Discussion 10 07-23-2006 10:10 PM
