Results 1 to 9 of 9
Thread: Help with HobbyCNC Driver
    Apr 2004
    Exclamation Help with HobbyCNC Driver
    Well, I did it......................I unpluged one of the motos from the driver while it was on................and yes, as stated in the instructions..............it blew something (says the UCN5804B's)............so I bought 6, overnighted..........replaced them and the 3amp fuse (it blew too) (it's the 120v power fuse).................AND.............the fuse keeps blowing shortly after turning the driver on.............AHHHHHHHHHHHHHH!
    Anyone knows if this should be a slow blow fuse or a fast acting fuse (I'm using the fast acting fuses).........
    Apr 2003
    yeah
    Email Dave Im sure he could help
    dave@hobbycnc.com
    Learn from the mistakes of others you can't afford to make them all yourself!
    Apr 2004
    Yes, I already did, and he responded shortly after my post above. I actually emailed him before the above post......
    Feb 2004
    hh
    this is exactly why I went for Compumotor drives; yes they may be old (well some of what i got are) and pulled from equipment but the protection is top notch; I did the same last night; the drive is unaffected by it; just lights an LED to say there is a fault
    Registered wjbzone's Avatar
    Apr 2003
    I burned up 3 of my HobbyCNC 5804 chips before I found the problem. Mine was a bad connection in the 6 pin connectors between the board and the motor (that I had soldered together). Since I replaced the connectors with a terminal block, it has worked great.
    I always blew the same pin on the chip. (pin 8) It got so hot it burned thru the socket.
    Bill
    Apr 2004
    I went and ordered Gecko G201 last night (and a 30v/10a transformer, 6500uf cap and bridge rectifier), I don't want to have that problem again...........
    I may still try to fix the HobbyCNC board, and replace the cables and connectors (as wjbzone did).
    Dave (of HobbyCNC) said to replace the socket for the UCN5804B that blow.
    Bill, I'll check and see how pin 8 is on my board........thanks....
    Apr 2003
    I had more problems with the socket the it was worth. It did not seem to be a solid connection. I soldered my 5804 to the PCB and left the socket out.
    Bill
    Apr 2004
    May as well leave the socket out if it has to be replaced any time the 5804 gets fried
    Apr 2003
    I think that's why I didn't get a solid connection on the socket. When the 5804 burned up (I saw a flame shooting out the side), the socket took some damage even if it didn't burn it up.
    1. HobbyCNC Unipolar Chopper Driver Kit!
      By HobbyCNC in forum Product and Manufacturer Announcements
      Last Post: 11-09-2009, 09:40 PM
    2. Need help with new Micromill 2000 and Smartstep/3 driver.
      By jimjovan in forum Stepper Motors and Drives
      Last Post: 11-08-2009, 11:07 PM
    3. HobbyCNC 3 axis board build and review
      By Jay C in forum Hobbycnc (Products)
      Last Post: 02-18-2005, 11:22 PM
    4. Replies: 8
      Last Post: 01-26-2005, 08:10 AM
    5. Fun with floppy stepper and driver
      By Konstantin in forum General Electronics Discussion
      Last Post: 03-08-2004, 02:18 AM
