Old 07-05-2007, 03:10 PM
frankg521's Avatar
frankg521 is an unknown quantity at this point
Db9
Can i use a DB9 connector for my steeper motors
Frank
Old 07-05-2007, 11:57 PM
vladdy's Avatar
vladdy is on a distinguished road
You 'should' be able to, probably...
I know it's kind of an ambiguous reply, but from what I remember, the standard pin connectors on common 'read PC spec' DB9 were rated for something just over 3A per pin, up to around 60v...this is going back quite some time to older process control equipment...
If you are considering using these for 4 wire [two coil arrangement] steppers, then by using two pins for each of the four connections required would give you enough for most 23 and some 34 series stepper motor / drive combinations...
Of course twisted pair style of wiring is recommended, as well as using the 'spare' as a ground, and possibly an extra for chassis ground and / or shield wire...my personal preference is to terminate shield wiring only on the drive end...
hope this is slightly clearer than mud..
..enjoy..
Old 07-06-2007, 08:38 AM
pminmo's Avatar
pminmo is on a distinguished road
Many dbxx's are rated 2A per pin, some mfg higher. Would depend on if your current requirements are less than the pin rating. If so then yes they would be ok.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 07-06-2007, 10:06 PM
davesaudio is on a distinguished road
Many norcomps are rated 5A --digikey
Seen some conecs rated 7.5A
Use a known type that you can get a datasheet for
D
maybe...
