Old 07-03-2007, 01:52 AM
babinda01 is on a distinguished road
Relay Woes
Hi
Just hoping someone may be able to help me out. I have a relay which is controlling my router on/off. This relay is tripping out my control randomly, mostly on turn off but sometimes on turn on. I have tried putting a 1n4004 diode across the coil (24VDC) of the relay, but I still am having troubles. I disconnected the router from the system so there is just the relay, but still troubles. Any thought on what else I can try.
Regards
Andrew
Old 07-03-2007, 07:50 AM
Al_The_Man's Avatar
Usually the diode will cure that kind of problem, you appear to have pinned it down to the relay coil itself, so you could try a AC RC snubber (.1µfd in series 330ohm) as well across the coil, although this normally would not be needed, is your 24v supply common connected to the common ground plate?
I would guess your Control common is not connected to the 24vdc common?
Old 07-03-2007, 04:23 PM
Relay Woes
Hi Al,
Yes all my dc commons are tied to a common earth plate. I will try the RC and see if it helps any. Will let you know how it goes
Regards
Andrew
Spindle woes inertialabs Bridgeport and Hardinge Mills 20 02-09-2007 06:43 PM
Wiring Woes..... Normsthename General Electronics Discussion 54 01-03-2007 03:38 PM
Any clues on my LPT woes? Greolt Machines running Mach Software 10 10-16-2006 01:51 AM
gibbs woes quemast GibbsCAM 0 08-17-2006 05:55 PM
Avatar Woes... JavaDog Forum Questions or Problems 5 04-07-2005 12:08 PM
