Old 06-29-2007, 11:58 AM
rbleth51 is on a distinguished road
Yaskawa Varispeed Spindle Drive component ID
Hi all. This is my first post, so here it goes.
Trying to get an older (1983-84) Hitachi Seiki CNC lathe with Fanuc 10T control up and running. It has sat for a while and been moved on a flat bad over the road to get to my shop.
All was going well chasing down the usual gremlins, loose cards, broken/losse cable, etc. Things are moving as they should and looks like it will run nicely, except for the spindle. It will not respond to a run command, M03/M04. The spindle drive is a Yaskawa Varispeed 626 MTII. A quick look at the drive after it failed to start the spindle revealed the "T DET" error LED was lit, meaning too high a tourqe on the motor was sensed before start up.
So I began a real basic inspection of the drive, cable conections, loose components, broken wires, etc. When I opened to swinging door on the drive to reveal its inner workings, I discovered an obvious problem. A component inside has a lead broken off from one end of it. Bellow is a picture of the component.
It looks to be a capacitor of some sort, but the markings are pretty vague, at least to my non electronics trained eye. Obviously the seperated lead pictured on the left was attached to the unit at the center of the side it is pictured on.
I don't know if this is the cause of the problem that is keeping the spindle from running, but it should be fixed before I go too much farther I think. I called Yaskawa and they were not a ton of help. The drive is so old that they don't really support it anymore. But the engineer I spoke to thought it was probably a filter capacitor of some sort. But that was all he dared say.
I have nor wiring docs for this unit and the ones I found on the Yaskawa site do not seem to contain this compnent. I tried to solder the lead back on but to no avail, the remaing part was not long enough even after scraping away most of the plastic coating around it.
If anyone could help me ID this part and figure out its specs so I can find a suitable modern replacement I would be forever gratefull. I have scoured the net and can find nothing based on the numbers on the unit. If any more info may be required to help someone who may know figure it out, let me know and I will get it for you ASAP. Below I will insert a pics of where the part was located in the drive. Thanks so much in advance for any help/info you can provide me with. Sorry for the length of this post.
Name:	Break Attachment Point.jpg
Name:	Solid Attachement Point.jpg
Best Wishes,
Rob
Old 06-29-2007, 12:25 PM
Al_The_Man's Avatar
That appears to be part or a RC snubber for High frequency suppresion, I doubt very much if it is affecting the immediate operation of the drive, The value appears to be .02µfd, I would say this jives with the physical size.
Did you try disconnecting the motor and see if you still get the same error?
There should be no torque output from the motor before the command is issued?
That probabally is a DC motor with wound field and tach feedback for that vintage.
Are you sure the LED does not come on after the spindle attempts to turn?
Old 06-29-2007, 12:53 PM
Yes, I was thinking for the size 0.0022µF. I read an artical somewhere saying that if no unit was given for a Farad rating, assume pico Farads. And the suppresion suggestion coincides with what the Yaskawa engineer I spoke with was thinking.
I did not, I wasn't sure if that would cause a problem or not, don't want to let out any "magic smoke" from the drive by accident. Is it safe to try that?
I agree, that is part of what has me puzzled. The spindle will move a little when the gear change comand is given (M40/M41), but does not even twitch when an S word for RPM and a run command (M03/M04) is given.
I had thought it was an AC spindle drive, but I am not sure. My knowledge is very little in this area. But I try to learn all I can every day.
I beleive that that is exactly when the LED comes on. I have not specifically checked the state of the LED's before the run command to see if it was on before or not. But I don not recall it being on any of the times I checked the LED's before I tried to start it. I looked them over before I attempted running and checked the meaning of all of the LED's that were lit against what the manual said they meant to be a little more sure it was safe to try and start the spindle/drive.
Would it be safe, in your opinion, to repower the drive, without the cap in place, for the purpose of checking that out? I would assume yes as the cap was not connected on the broken off end anyway. If you think yes, I will power it up in a few and check. But like I said, I am pretty sure it does not come on until after it gets the run command.
Below is a photo of the drive nameplate data. Maybe that will help to determine whether or not the motor is AC or DC. I feel kind of ashamed that I don't know for sure.
Name:	Drive Nameplate.jpg
It says inverter drive on it so I had assumed AC for the motor. But like I said, not sure.
Even if the bad snubber cap is not my problem, and help on figuring out a replacement cap for it? I would like to replace before I run the spindle too much, if I can get the spindle to run at all. What about polarity? None is labled on the originall. All the caps I have looked at at Mouser are of differing voltages. Heck, I am not even sure if the lable of "600V" on the original in the photo really is 600 volts. And if so, is it VAC or VDC? My electronics ignorance is really showing through now I am sure. And would mees things up if I replaced the cap with one from Mouser rated for 1000V? The one I found at Mouser that, in my un-educated judgement, best matches the orignal was rated for 1000V and 0.0022
µF.
Thank you so much for the help so far! Hopefully I can get this thing going with the help here.
Best Wishes,
Rob
Old 06-29-2007, 01:16 PM
Mike Nash is on a distinguished road
The capacitor is a 2.2uF 600V non-polarized film capacitor. It's a snubber. Newark has this discontinued (non-Rohs compliant - no big deal in the US and solders more reliably) part that should work for $5.94. http://www.newark.com/jsp/Passives/F...sp?sku=46F1232
Be warned that not all film capacitors make good snubbers. It has to do with the way the end of the "tape" is connected to the leads.
Since you are not getting any actual trip condition, it's probably not your immediate problem. You could have other problems due to it however. I can't advise running for long without it. The TDET light is just telling you the torque level has reached the point set by the TLIM pot. IF this light is on but the motor is not turning you may have a mechanical stall condition, i.e. the motor or load is requiring more torque than the drive is set to deliver. Turning TLIM up might start it turning or it might burn something up or break something. I'm wondering if there is a spindle brake that is not disengaging or some other reason such as rust or gunk that the spindle cannot turn freely.
Your drive is an inverter, hence AC motor. The manual I'm looking at is here http://www.yaskawa.com/site/Support....ucts%20Defined
Good luck!
Old 06-29-2007, 01:55 PM
Mr Nash,
Thank you so much!! That is exactly the kind of info. I was looking for. You even found and provided a link to a suitable replacement for me. I had spent hours and hours trying to find one. Chasing my tail mostly as I was not certian what values the orginal had that I was replacing. SO you think it is 2.2uF? The fact that it was labled 2.2K threw me, I was thinking K might be referencing or = 1,000. I will place an order for a few of the new ones you linkd to for me when I am done this post. For that kind of money, even if it is the wrong thing, it is worth trying.
I was pretty certain it was an AC drive and motor. But I have spent so much time chasing my tail on this one, running into dead ends, etc. that I had an overwhelming feeling of not being certain of anything any more. LOL
The spindle nose seems to turn fairly freely by hand. Doesn't seem to be bound by any pins, gears, shifting mechanisms, etc. It may have a brake, but I don't think so. I have seen nor reference to one in any of the docs I have or on the machine. If it does have one, and it is "on" it is pretty weak as I can turn the spindle by hand without too much trouble. And it does move without any visible trouble when the gear change is comanded, and seems to change the gear succesfully.
I did find those docs/manuals on the Yaskawa site, but was unable to determine any answers from them on my own. I will be reading them through pretty closely over the weekend though.
I will be powering up and checking the LED states for certain after I order the new/old caps. I will post what I find.
Any other information, opinions, help are still much appreciated and wanted as the spindle is not turning yet. Thanks!
Best Wishes,
Rob
P.S. Sorry about my poor spelling, my education is in Mechanical Engineering, so numbers more than words are my thing. And I have not figured out if a spell checker is available here.
Old 06-29-2007, 02:54 PM
Al_The_Man's Avatar
You need to be sure, if the value is in fact much lower than 2.2 µfd, a 2.2µfd can fry the resistor if it is across any kind of AC supply.
I would have considered the µfd value high for a HF snubber.
If everything is free but as soon as the motor moves you get a Torque alarm, it could possibly be a connection on the Resolver feedback.
You could remove the motor leads (3ph) and try to run, you may get another alarm, but if you still get the TL alarm, I would suspect the switching components.
If it sat for a while.I assume It wasn't mothballed because of a shorted spindle problem?
Old 06-29-2007, 08:49 PM
It's definitely a 2.2uF. I looked around to see if we had one in the bone pile but didn't see any. We don't see many (if any) of the spindle drives in for repair, but get a lot of the larger Yaskawa VFDs. We've been selling/repairing them for years. Unfortunately, we have a limited series of prints and the spindle drives are not one of them. I reckon I've personally only seen one and that was a few decades ago.
I'm going to correct my earlier statement after rereading the (poorly) written manual. The TDET pot sets the torque level at which the TDET LED turns on. It is actually just there to make available a contact output to signal some user adjustable torque level has been reached for some user determined reason. I.E. it doesn't mean a whole lot unless it is being used for some external circuit that may be shutting you down if the torque exceeds some level. Try turning up both TLIM and TDET. But also record where thay are now before you do.
Are you getting any other LEDs?
Old 07-02-2007, 11:32 PM
That is something I had not dared to try yet. I wasn't sure if something would fry if I tried running the inverter with no load connected.
No, it was making chips the morning we picked it up from the shop that sold it. They had taken delivery that day of a brand new Daewoo Puma I think it was. Much bigger machine and brand new. They needed the increased capacity of that machine.
Thanks for the advice/ideas.
Best Wishes,
Rob
Old 07-02-2007, 11:39 PM
Al_The_Man's Avatar
It should not make a difference with the motor 3ph disconnected.
Did you try what Mike suggested?
Old 07-02-2007, 11:57 PM
Mr. Nash,
Sorry it took so long for me to reply to the last message you posted. I wound up with strep throat and a couple other nasty things and have been down for a while.
Unfortunately prints for this drive seem to be near impossible to locate, at least for me anyway.
I did not get a chance to turn up the TLIM pot yet. But I did change the TDET pot a little. 2 changes resulted. First the spindle actually rotated a little, maybe 1 rev, and then stopped. Second, the TDET LED did not light at any time during my atemps to run the spindle. Hopefully I will feel well enough Tuesday to try advancing the TLIM pot a little.
Sort of. I did get my wife to come down to the shop today so I could watch the drive while she ran the control to try to start the spindle. But it is late and I can't find the paper I noted it on.
I ordered a couple of the capacitors that you pointed me to with the link at Newark. They are supposed to arrive Tuesday. I don't want to play with the drive to much until I get that put back in place. Thanks so much again for the info on that. It would have taken me forever to ID that part, if I ever figured it out at all.
I did notice another anomally on another electronic component in the drive. But I will post that in a seperate message.
Thanks for all your time.
Best Wishes,
Rob
  #11   Ban this user!
Old 07-03-2007, 12:25 AM
New Part to ID/Diagnose
While I was adjusting the TDET pot I noticed something. The part pictured here:
Name:	Unknown Part With Goo Number Side.jpg
It caught my eye as it appeared that something may have "oozed" out of it at some point. I am reffering to the white material that is on either edge of the part. Unfortunately I do no recall if the white goo had been there before or not. It was not warm at all to the touch. And it was not sticky or in any way runny/liquidy (please excuse the poor teminology, it is 1:15 A.M. here). That is to say it was fairly solid. Not hard, but like a spray foam that had long since set.
Like I said, I had no idea if it was like that before I started trying to get the spindle running or not. The only reason it caught my eye was that it resembled the look of some capacitors in my PC's power supply that had failed and similar material has flowed out from them.
There are many similar parts to this one on the same card, and none show any evidence of the white stuff on them. And not one of them have the same numbers as this one printed on them nor do they appear to be the same size. Some seem to be a little larger and most appear to be a little smaller.
As with the capacitor from before, I have no idea what this part is. So I have questions.
1. Anyone have idea what this part is? (in case the white stuff is bad and it needs to be replaced, if it can be replaced)
2. Knowing what the part is, could the white stuff have come from it?
3. If the white stuff could have come from it, and did come from it, is it bad? ( I think the obvious answer to this one would be yes, but I really have no idea) In other words, is it an indication that the part has failed?
Here are a couple more pics to help in the ID/diagnosis.
Name:	Unknown Part With Goo Top Side - Close.jpg
Name:	Unknown Part With Goo Top Side - Wide.jpg
Thanks as always for your time and help. It is greatly apprciated.
Best Wishes,
Rob
Old 07-03-2007, 07:56 AM
Al_The_Man's Avatar
The 'White stuff' appears to be silicone rubber, it is used to cushion components like those that are prone to break off due to vibration, it is applied at board assembly time.
Was anything disconnected during the move? such as spindle motor etc?
Yaskawa SGDH and SGDA servo motor/drive wiring questions rpseguin Servo Motors and Drives 62 12-02-2009 06:43 AM
Yaskawa Varispeed 626 MT bradodarb Phase Converters and VFD 1 04-27-2009 08:38 AM
Reconfiguring Yaskawa Drive for Position Control? rpseguin Servo Motors and Drives 13 10-31-2006 07:09 PM
Yaskawa AC Spindle Drive problems...blown? nlh Servo Motors and Drives 0 08-04-2006 07:19 AM
problem with Yaskawa V7 drive rebrumm Phase Converters and VFD 4 05-22-2006 04:40 PM
