Old 06-25-2007, 09:09 AM
xitian is on a distinguished road
Ammeter and Voltmeter for controller
I'm building a gecko based controller for my mill and would like to be able to monitor the voltage and amperage my drivers / steppers use from my power supply. Would I wire my ammeter and voltmeter in series with the driver power supply inputs or in parrallel?
PS(+)--->Voltmeter--->Shunt Resistor--->Ammeter--->Drivers--->PS(-)
OR
PS(+)--->Voltmeter--->PS(-)
PS(+)--->Shunt Resistor--->Ammeter--->PS(-)
PS(+)--->Drivers--->PS(-)
Thanks for any help!
Old 06-25-2007, 09:52 AM
Gold Member
CJL5585 is on a distinguished road
Voltmeter will be wired to power supply + and - outputs.
Ampmeter will be wired in series using power supply + output.
Old 06-25-2007, 10:03 AM
pminmo's Avatar
pminmo is on a distinguished road
Depending on setup your ammeter maybe of little use.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 06-26-2007, 01:27 AM
hixfixit is on a distinguished road
Just to clarify
To be specific:
Voltmeter: across supply, +ve and -ve. (as above).
Ammeter: shunt goes in series, ammeter wired across shunt (parallel with shunt). Can use +ve or -ve line, as current out = current in. Note: ammeter may go backwards, so swap wires if required.
The shunt provides a minute resistance to allow current through the ammeter. Wiring in series without shunt will destroy ammeter.
Old 06-26-2007, 09:11 PM
vulcom1 is on a distinguished road
It depends also how much current you are putting through the shunt for the meter. If purchasing a 10 amp meter for example the shunt has to carry the 10 amps or more and should be more. If you do some searching on the web look for shunt's. I made mine from a millamp meter with a home made shunt which is wire wound in a coil of a certain length. I use it on the foam cutter bow for setting the heat. It may not be the answer for you but my feeling is the case looks better with meters and it helps troubleshoot when something has gone wrong. I'm from the old school abnd still prefer them instead of the idiot lites.
John
DX-32 Controller hilljk46052 Bridgeport and Hardinge Mills 5 08-09-2007 09:48 AM
DeskCNC 2nd. gen controller AND HobbyCNC Pro Controller maycom DeskCNC Controller Board 1 06-02-2007 01:33 PM
Help, I'd like a new CNC controller Chris64 Gecko Drives 5 01-03-2007 07:23 PM
Cnc controller. Smackre General Electronics Discussion 0 05-02-2006 08:56 PM
Controller or cam? Halfnutz Mach Software (ArtSoft software) 2 04-19-2005 07:21 AM
