I have bought a Micro-Dispensing valve for a project of mine and I`m finding their Spike and Hold Driver instructions a bit confusing as it refers to two power supplies. The valve requires a Spike Voltage of 24vdc set for 0.3 millisecs and a Hold Voltage of 3vdc I am hoping to use a single power supply and would greatly appreciate being shown how to incorporate components to reduce one of the psu outputs to 3vdc. Is this feasable ? I`m such an electronics duh-brain this is the psu I have http://cgi.ebay.co.uk/24V-10Amp-250W...QQcmdZViewItem Please see the attached pics for the Driver Instructions |
| The ideal way would be of course to have a combined supply, you could use a zener circuit, simple, but not very efficient, (heat waster). This would consist of a 50ohm 20w resistor from a 24vdc terminal in series with a 3v 2w zener to ground, the 3v would come off the top end of the zener and ground. BTW all the 24vdc outputs on the supply are common to each other. Al.
| You might want to add a 100µfd capacitor across the zener output. If you google zener resistor circuit you should find some more examples. Al.
| Fanuc 5 Voltages | wassa64 | Fanuc | 11 | 12-11-2008 09:46 PM |
| Fixed Drive Voltages | The Speaker Guy | Stepper Motors and Drives | 5 | 12-28-2006 03:13 PM |
| Help! Triggering with very small voltages | vacpress | General Electronics Discussion | 30 | 11-06-2006 05:10 PM |
| diffrent stepper voltages | JohnnyYuma | Hobbycnc (Products) | 3 | 07-31-2006 07:24 PM |
| Confused about Steppers and Voltages. | cap9qd | Stepper Motors and Drives | 8 | 06-03-2006 09:17 AM |
