I have a shunt wound 1.5 hp dc motor and c6 speed control board from cnc4pc. Does anyone have any suggestions for a dc drive with reversing that would work with my motor and control board at a reasonable price, around $300? |
| You did not mention the voltage of the motor? If 90~120vdc and you require an analogue input controller then there are several vendors e.g. Baldor that sell a relatively cheap DC controller with field supply capability, You would have to set up the reversing by relay which each would typically be picked up by the M3/M4 command. There are also usually several of these on ebay of re-labeled by various manuf. If you get one from your Baldor rep. and are putting in an enclosure , they can be obtained without the case and Pot. for about 1/2 the price ~($100.00). Al.
| TI/Unitrode made an IC called the Uc3637. Their U-102 application note shows how to build a bidirectional speed control with the IC and an external current aplifier. Essentailly ALL analog servo's use this particular method of speed and direction and currentcontrol to some extent or another. |
| You would need also to provide the shunt field circuit, which could be from 50v to max armature DC, the name plate should show it. Al.
| Fanuc axis drive control PCB- S Series | M.RISHIKESH | Fanuc | 0 | 12-04-2006 10:25 AM |
| Reconfiguring Yaskawa Drive for Position Control? | rpseguin | Servo Motors and Drives | 13 | 10-31-2006 07:09 PM |
| step and direction control for opto22 servo drive | drewgarth | Servo Motors and Drives | 4 | 05-21-2006 01:31 PM |
| What motor drive for an arm? | nervis1 | RC Robotics & Autonomous Robots | 9 | 12-16-2005 02:30 PM |
| Control Technique Digitax DBE 750 AC Servo-Drive | GalaticDan | Servo Motors and Drives | 6 | 09-16-2005 06:32 AM |
