| http://www.lindsayengraving.com/othe...rests/dro.html There is a previous post about this, where I found you could input an encoder direct without the buffer transistors. Al.
| The output method (quadrature signal) from scales are often identical to rotary encoders, just make sure they are 5v square wave signal. Al.
| You don't really need a break out board as the encoders/scales should go direct into the parallel port if they equipped with TTL line drivers. But you can get IDC ribbon to screw terminal connectors from any of the electrical terminal manufacturers. Al.
| There is no programming to do on the Lindsey site DRO, Art has an upgrade on his. http://bellsouthpwp.net/A/r/Arts_home_page/DRO/ Al.
| Yeh, but he said "windows" based and the program is "dos" based! Remember we went through this a few weeks back and finally concluded the gentleman in question was trying to run in a "dos box" and as soon as he went to pure dos, things started working!
__________________ Art AKA Country Bubba (Older Than Dirt) |
#10
| what i am trying to make is a kind of measuring table, like the quality control systems that i have seen. I am thinking about using a surface plate and linear guides and encoders, so i gues i am trying to do more than a dro. thoughts or laughter ae re welcome |
#11
| As long as you do not want to store data or move the mechanism under control of the program, then it should work for you, depends on measuring accuracy desired, and will depend on the precision of your mechanical set up. As stated, this is a DOS program, but if all you want to do is measure then this may work for you. Al.
| Here it comes...Windows Vista... | fatal-exception | Mach Mill | 2 | 02-08-2007 09:56 PM |
| Klinger MD4 Help on DOS or Windows | nostradamus2 | Visual Basic | 0 | 01-17-2006 05:58 PM |
| Windows XP or Windows 2000 better with Mach2 | Beezer | Mach Software (ArtSoft software) | 2 | 10-18-2004 10:08 AM |
| Windows Xp | i228208 | TurboCNC | 11 | 04-25-2004 09:57 AM |
