Old 04-06-2004, 07:10 PM
Sanghera is on a distinguished road
Parallel Breakout Board
Does anyone have a good source for a parallel breakout board. I have heard of the Axxus one's, how do they perform. Also, what does "opto-isolation" mean. I read it on another thread, something to do with not frying your computer or something? Also, does the Axxus board have "opto-isolation"?
Thank you very much.
I really appreciate it.
Old 04-06-2004, 07:55 PM
trubleshtr is on a distinguished road
Sanghera, I was just about to post a question regarding the db1v20 pc interface board from "axxus" technologies. I have purchased it and I am trying to find out if it will work with "rutex" driver R990h system. I plan On driving three amtek motors with them (yes they are the infamous tape reel motors)
If anyone has used the axxus board with rutex driver R990h I would greatly appreciate feed back.
As far as "opto-isolation" I don't believe the pc board is, Opto-isolation just means that there is no "physical connection" between the input and output of the signal. ie. you could have a low voltage input that signals controling larger voltages down stream away from sensitive electronics. It is also a way to have people or operators using push buttons ect.. that are a low voltage instead of higher voltages that could potentially harm them if the electrical circuit should fail.
I will try to pass on any more info about axxus, have you checked out their web page?
menomana
Old 04-06-2004, 07:59 PM
I found the link to axxus technologies, maybe this will help you?
http://members.shaw.ca/axxus/db1v20info.htm
menomana
Old 04-06-2004, 08:24 PM
abasir's Avatar
abasir is on a distinguished road
The quoted section is correct. In opto-isolation, the 'connection' is done using light (LED+Light Sensor).
BTW, the axxus board is NOT opto-isolated.
Stupid questions make me smarter...
See how smart I've become at www.9w2bsr.com ;-P
Old 04-07-2004, 01:02 AM
Ok, cool. So, do you think that I would need a breakout board with opto-isolation? What other Parallel Breakout Boards are there that anyone would suggest, or even to just check out.
Thank you all for your replies.
Old 04-07-2004, 01:51 AM
abasir's Avatar
Opto-isolation not a must. If something were to go wrong, most probably the breakout board will fry first. Just be extra careful when wiring-up your system I don't even use a breakout board but I triple check my wiring with voltmeter before connecting to the PC
Old 04-07-2004, 09:41 AM
DR-Motion's Avatar
DR-Motion is on a distinguished road
"Opto-isolation not a must. If something were to go wrong, most probably the breakout board will fry first"
The worst thing that can go wrong is getting the motor voltage feeding through your breakout board. This could happen if the evil swarf lands on your stepper driver and causes a short. The breakout board without opto isolation will not fry because it contains only connections to your parallel port... it's the parallel port that would fry. If you are using a PC in a box you would have to replace the $15 parallel port board but if you are using a laptop ... bye laptop.
The good news is that most driver manufacturers have opto isolation between the motor power and the step/dir inputs. So if you are not machining anything conductive (eg. aluminum, brass, steel ) or if you go to great pains to protect your electronics then no problems.
I once found a tiny sliver of aluminum causing a short between my logic ground and chassis ground that kept my machine down with intermittent problems for almost a full day. Luckily no damage.
HTH Gary
embrace enthusiasm to accomplish the task
Gary Davies... www.durhamrobotics.com
Old 04-07-2004, 02:47 PM
Thank you very much for your reply.
Old 04-07-2004, 07:15 PM
abasir's Avatar
Take note that some breakout board have buffer IC onboard but, like Gary says, some don't. Those without buffer IC will cause the parallel port to fry if something goes wrong
Old 04-07-2004, 08:35 PM
So, does that mean that I don't want buffer IC? Does the Axxus Parallel Breakout Board have Buffer IC.
Also, if the Gecko has Optp-Isolation, does this mean that I don't need it for the Parallel Breakout Board.
Thank you very much for the replies.
  #11   Ban this user!
Old 04-08-2004, 12:13 AM
abasir's Avatar
I would want one with buffer IC because it safeguard my parallel port. If the breakout board fry I can just buy new one to replace it.
If you are using gecko, IT IS opto-isolated; thus, ANY breakout board will do. No breakout board also fine. Gecko spec below:
G201 FEATURES:
0.3A to 7A phase current
24V to 80V power supply
10 microsteps per step
Size 17 to 42 motors
Mid-band resonance compensation
Low-speed resonance nulling trimpot
Auto current reduction
200kHz max step rate
<<<< Opto-isolated Step and Direction >>>>
20W dissipation at 7A per phase
Silent: 20kHz master oscillator PWM
0C to 70C operating temperature
Rugged: All n-channel TO-220 MOSFETs
LED power indicator
Small size: 2.5" by 2.5" by 0.82" (63mm by 63mm by 21mm)
Light: 3.6 oz (100gm)
Anodized aluminum package
Modular 2-piece main connector
  #12   Ban this user!
Old 04-08-2004, 12:53 AM
So, I'm sorry if I missed it, but does the Axxus or Gecko have Buffer IC?
Thank you.
PICStep V3.1 and Opto breakout board Garfield2 Open Source Controller Boards 3 04-26-2007 12:04 PM
USB Breakout Board vs. Parallel dwwright Mach Software (ArtSoft software) 3 12-09-2005 01:30 PM
Breakout Board ckirchen Product Announcements & Manufacturer News 11 06-20-2005 11:52 AM
in lieu of a breakout board fly_champ General Electronics Discussion 3 03-01-2005 09:42 PM
breakout board comparison xkbal General Electronics Discussion 10 02-19-2005 08:12 AM
