Old 05-21-2007, 10:34 AM
cueshark is on a distinguished road
router speed controler
can i use a router speed controler to vary the current going into a torodial transformer? if that will not work, can i use it either before or after the capcitor when it is dc to vary the voltage? i need 95 volts max.thanks greg
Old 05-21-2007, 10:52 AM
Al_The_Man's Avatar
Not the best idea and it will not work in all the senario's you mention. Also the technology varies on router controls from PWM to phase angle control.
I would look at removing/adding turns to the Toroid first.
Do you want to increase or decrease the secondary?
Old 05-21-2007, 01:41 PM
i have a 90volt dc motor.. theps output is 92 volts i was thinkingthat maybe i could use the router controller to slow the motot down by using it instead of buying a motor controller rated for 110 volts @ 15amps. i as just wondering, maybe i could use something i already had instead of buying a controller. thanks for sharing your knowlege. greg
Old 05-21-2007, 02:16 PM
Al_The_Man's Avatar
If it is the AC speed control that is used on universal motors, you may be able to use it in the AC secondary between the secondary and the bridge.
Is it a Universal motor or a permanent magnet field type?
Old 05-21-2007, 03:26 PM
i do not know! it is a lesson treadmill motor. how do you tell what is what? greg
80amp, 12/36 vDC PWM Motor speed controler tenmetalman Bridgeport and Hardinge Mills 3 07-10-2006 08:48 PM
Spindle speed controler and encoder Parameter Mach Software (ArtSoft software) 1 12-10-2005 06:30 PM
Using DC speed controler for Power Supply CNCDust General Electronics Discussion 3 04-05-2005 08:07 AM
Controler for new router table DESERT RAT General Electronics Discussion 20 06-16-2003 11:30 PM
