Old 05-20-2007, 07:27 AM
REVCAM_Bob is on a distinguished road
Building Touch Probe and Toolsetter...
I previously have posted regarding this topic and got quite a few good suggestions as to the way to go. It appears the Renishaw style use an infrared transmitter, however several people have suggested useing an radio
transmitter to send out the signal.
Al_the_man, if you are out there, you mentioned you might have circuits somewhere for a simple transmitter/receiver?
Is anyone aware of a transmitter/reciever that could be purchased off the shelf and incorporated into a probe?
By the way, I found a commercially available switch with 1 micron repeatability for around $180 that could be used in both a probe and tool setter.
Old 05-20-2007, 08:25 AM
dfurlano is on a distinguished road
Can you post a like of the tool setter?
Dan
Old 05-20-2007, 09:54 AM
pictures of probes and tool setters
see attached for some pictures, there are other types alsoe i.e. laser non contact tool setters, but most probes look very similar...
Old 05-20-2007, 10:03 AM
I'm sorry I type to fast - I meant can you post the links.
Dan
Old 05-20-2007, 10:31 AM
samco is on a distinguished road
I am using a microswitch as a tool length setter. (I like to mill circuit boards and I don't have a quick change tooling.)
I have found that the cheap microswitch that I mounted on the table gives me +/-.0003" repeatability. More that accurite enough for me. I have not actually used it in a g-code program yet - but I am can't wait.
sam
Old 05-20-2007, 10:56 AM
Al_The_Man's Avatar
I did post it before but here is the link http://www.rentron.com/remote.htm I have used some of the RC products and there is also IR circuits.
Old 05-21-2007, 05:10 PM
Thanks Al, I will check it out...
Old 05-22-2007, 10:33 AM
Rentron RF circuits
I checked out the Rentron site, and ended up calling them up. They told
me there product would have about a 20 to 30 milisecond trigger time, and
after doing some calculations, this would require an immensely slow feedrate
i.e. if moveing 20 inches per minute, the probe would move 0.6 inches in 30 milliseconds. The Galil board I am useing claims to have a high speed latch
function that can detect encoder position in .1 micro second....
So I need an rf circuit, if possible, that is much faster than the 20-30 miliseconds optimally 1 millisecond or even better .1 millisecond. It is possibly
to do some workaround if these speeds are not realistic.
Is this speed reasonable with a custom encoder?
Any thoughts?
Old 05-22-2007, 01:48 PM
Bent is on a distinguished road
"i.e. if moveing 20 inches per minute, the probe would move 0.6 inches in 30 milliseconds."
If you do the math on this then you are only going to move 0.009999 inch in 30 millisec or ????.
Bent
Old 05-23-2007, 06:43 AM
Yes you are correct...
Yes you are right, I forgot to translate the 20" per minute into speed/second.
This brings the time frame for the probing into a little more realistic range.
Does anyone know how to tweak these Rentron send/recieve circuits to get
faster response times? The guy at rentron said something about writeing your
own decoder?
If I can find someone that can do it, I would be willing to pay for the help....
Who want to make a touch probe? MrBean Digitizing and Laser Digitizing 114 09-30-2010 04:39 PM
Probe and toolsetter suggestions? REVCAM_Bob General Metal Working Machines 15 12-31-2007 06:12 PM
Z axis touch probe Swede FlashCut CNC 7 08-29-2007 12:09 PM
Pop-up tool touch probe dmealer General Metal Working Machines 4 04-04-2005 06:47 AM
homemade 3D touch probe? cnczane DIY-CNC Router Table Machines 26 06-26-2004 07:17 AM
