Old 05-18-2007, 03:34 AM
ronald44 is on a distinguished road
Power Supply HELP!!!!!
I purchased a 4XCNC15B controller card from dtllc.com that requires a filtered 5vdc to operate the board. It is a 4 axis controller with connections for limit switches and other relay's. It is capable of handling up to 15amps per axis. I have also acquired 3 KL23H295-43-8B unipolar steppers to work with this controller which itself is unipolar by design. The manufacturer includes a schematic to use PC power supplies to run each motor. Whilst this may be fine for NEMA 23 motors, I'm using NEMA 34 motors.
What I need help in the worst way with is: what do I need in the way of transformer, capacitor, rectifier and resistors to provide 48v for the drivers, 5v for the controller itself and 12v to run fans and limit switches and an E-Stop relay. The steppers in question need 3.01v, 3.3a, 0.7ohms and provide 906 oz. in. After I can figure out these requirements out I can then find someone local to assemble it.
Ronald Lambier
Old 05-18-2007, 07:40 AM
Weldtutor's Avatar
Weldtutor is on a distinguished road
Ronald
This link,
http://www.campbelldesigns.com/files...ply-part-1.pdf
will take you to a web site that will answer some of your questions.
Old 05-19-2007, 10:07 PM
I've been using the power supply editorial at campbelldesigns.com, thats where I am at the moment in my design. I think I've found a transformer at Triac.com, now I need the capacitor, bridge rectifier and the resistors and cables.
Ronald Lambier
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power supply kenlambert CNCzone Club House 3 03-21-2006 10:07 PM
power supply for someone dertsap Open Source CNC Machine Designs 0 03-05-2006 10:30 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
