Old 05-16-2007, 08:53 AM
L98FIERO is on a distinguished road
Problem with Campbell Combo Board
I've nearly completed the retrofit of the CNC on a mill using Mach 3, the UHU servo boards and a Campbell Combo board but I'm now having problems getting the spindle relay to operate and have had no luck in getting hold of Bob Campbell.
When I reset the controller the charge pump relay closes and the LED lights and the main relay for the 3Ø closes.
In MDI;
M3 nothing happens
M4 the direction relay closes and the LED lights.
M5 relay opens and the LED turns off.
M8 coolant pump relay closes and the LED lights.
M9 coolant pump relay opens and the LED turns off.
I have output #1, port 1, pin 1 for M3
I have output #2, port 1, pin 1 for M4
I have output #3, port 1, pin 14 for M7
I have output #3, port 1, pin 16 for M8
Because the other functions work I was thinking that the problem may be with pin #1 or the cable. Any suggestions and advice on the problem would be appreciated.
LaVerne
Old 05-22-2007, 06:54 PM
My apologies to Bob, apparently he did contact me before but it got caught by my spam filter. He has contacted me again and I'm trying his suggestions and we will see where it goes.
LaVerne
Campbell Breakout Board wildcat Industrial Hobbies (Support forum) 57 04-19-2011 01:23 PM
Control panel w/ Gecko 202, Campbell breakout board Norsksea General Electronics Discussion 0 01-27-2006 06:16 PM
Campbell Combo board Router hookup Trainhound General Electronics Discussion 1 11-30-2005 01:46 PM
I/O board problem squarewave CamSoft Products 16 10-28-2004 11:00 PM
Bob Campbell Break-out board? A&P Mech General Electronics Discussion 7 10-07-2004 06:53 PM
