| hello im french ![]() i need to put the tension of the torch into my PIC controller for a future open source THC but i need schematic of this input, like filter... regulator... voltage divider... opto... ??? pic input = 0...5 Volt max thanks |
| Bon Jour, By tension, I assume you mean torch voltage? There is an Opto isolator that translates voltage in to a proportional resistance out, You may be able to monitor the voltage by voltage divider into the Opto and use the resistive output for a Analogue input PIC. If you wish to persue this idea I can look the opto number up, I picked a few up a while ago, meaning to experiment with them. Al.
| ok ! thx the torch "voltage" is not very clean, how to smooth the voltage ? without, my PIC is crazy look there : http://patimg2.uspto.gov/.piw?docid=...6RS=PN/6028287 |
| The IC is H11F1 http://www.fairchildsemi.com/ds/H1/H11F1.pdf You could stabilize the voltage somewhat by using an Electrolytic across the bottom end of the divider, You would not want to use to high value due to long time constant, if may take some experimental time to arrive at a suitable value. Al.
| Tension/compression tap holders | Caprirs | General Metalwork Discussion | 8 | 04-05-2007 07:59 AM |
| Wire tension | gguidi | CNC Wire Foam Cutter Machines | 1 | 10-20-2006 09:40 AM |
| Belt Tension Adjuster Design | mxtras | Mechanical Calculations/Engineering Design | 8 | 05-16-2005 10:33 AM |
| Hitachi Seiki MH 400 drawbar tension | kmuller | General Metal Working Machines | 1 | 11-07-2003 01:10 PM |
