  #13   Ban this user!
Old 06-01-2007, 12:45 PM
mr jones is on a distinguished road
Phil....
Ive gone to your site a number of times and each time i cannot see the forrest for the trees.......either theres SO MUCH information I am getting lost in it all or else I am using some hitherto unknown configuration of these chips.
I am using the schematic/wiring diagram directly off the L298 PDF datasheet .....is anyone THIS schematic on your site and if so where can i find it?
I apologize in advance for necessitating all the handholding and points in the right direction.
And I am grateful in advance for i know you have the answer i require and are happy to give it.......so thanks and i look forward to your response!
Cheers!
Mr Jones
  #14   Ban this user!
Old 06-01-2007, 02:03 PM
pminmo's Avatar
pminmo is on a distinguished road
Mr. Jones,
Attached is the basics to what you need to do. I just showed the pins necessary to hook up one board to the parallel port. I colored the pins for Step and Direction to agree with the MACH3 setup I show on my website: http://www.pminmo.com/wiki/index.php...105a_interface
You also need other wiring to go with the datasheet board. A method to set Vref for the motor current, I just showed a pot. A method to set half/full step or hardwired if your sure which step method you want to use (I would recommend half step) It is drawn as enable always enabled (i.e. power motors will be locked). I don't like an always locked condition and in my setup control enable with pin 14 from the lpt port.
Hope this helps.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
  #15   Ban this user!
Old 06-04-2007, 09:21 AM
Oh WOW thanks Phil man!
that schematic is exactly what i was wonderin and you totally rock my lameness with your superior intellect and plethora of information!
Kudos bud! this site rules!
Troubles with L297/L298 ragrillo Open Source Controller Boards 43 10-21-2010 08:10 AM
L297 or SLA7051? and some other things Konstantin Open Source Controller Boards 3 07-27-2006 01:49 PM
L297-8 and 4axis BOB aem_argentina Open Source Controller Boards 1 02-20-2006 09:55 AM
L297 for unipolar? Mcgyver Open Source Controller Boards 31 12-10-2005 12:13 PM
L297-8 PCB - who is interested / anyone sells them? RomanG Open Source Controller Boards 22 10-26-2005 01:42 PM
