  #25   Ban this user!
Old 02-25-2010, 04:07 PM
pfred2 is on a distinguished road
Mine works as well. But when I hooked two up together I found that it did not. Then I had to optically isolate the step and direction inputs on the circuits to eliminate noise coupling and propagation between them. I also used a schmitt inverter to square up the output of the optocoupler to my sequencer.
Something like this:
http://img291.imageshack.us/img291/1287/optoface.png
Just in case you run into the same sorts of troubles as I did.
  #26   Ban this user!
Old 03-02-2010, 12:58 PM
wini is on a distinguished road
What about the response ??
hi guys,
when i have read about STK6713BMK4 i found that this IC respond to low level of sequence [ page 1 and 3 in datasheet ].
that means that this ic does not compatible with L297 which give high level of sequence .
for that you need to use STK6713AMK4 which responses with High level ,is it not ?
any suggestions?
  #27   Ban this user!
Old 03-05-2010, 10:04 AM
patriciooholegu is on a distinguished road
hey people.
I have 4 stk6712bmk3 removed from a ricoh sorter-stapler from copier machine FT6655. Great stuff but not working at all.
Some one have made the circuit on eagle?
