Old 04-17-2007, 03:33 AM
hotponyshoes is on a distinguished road
Delem DAC 350 cnc controler..
Hi all,
I have been given one of these:
http://www.delem.com/index.php?id=59&type=1
My evil plan for it (they are made for controling shears) is to use it for a plasma cutter to cut stright bits. I am currently making a plasma table for the shapes but we use a load of stright cuts and I would like to make a simple shere only use a plasms rather than a blade. From what I can work out the controler will let me set the back stop length and really thats all I need as it will be simple enough to hold the button and drag the torch accross the sheet by hand.
Now, the problem! I only have the front part (the bit with the buttons and screen) not the din rail mounted unit in the picture.
I will be fixing the torch to a liener rail/carrige and will set the back stop on a couple of rails with either a screw turned by a stepper or a linear actuator.
Anybody know what the best way to interface the controler with a motor is?
Would I need the dedicated box for the 350 or is there a generic product I could use?
I do not know if the box would contain a stepper driver and feedback sensor or wether it would need an input from a position sensor for backstop location.
Apart from power the only connections on the 350 are a 3 pin wire (marked P956) and a 9 pin d-sub connector.
When powered up the unit shows 'Error - No HSL - Press any key to continue'
but it looks to be working fine.
Is this likley to be worth setting up? Hopefully I would be able to program say 10 lengths of cut and just feed the sheet through to save manual adjustment of the backstop each time.
All advice welcomed! Thanks!
what fanuc controler do i have? bcdracing Fanuc 3 03-21-2007 08:17 PM
mazak 32 controler gosserwb Mazak, Mitsubishi, Mazatrol 4 02-14-2007 07:53 PM
mazak 32 controler gosserwb Mazak, Mitsubishi, Mazatrol 2 02-11-2007 04:55 PM
Help for Matsu****a controler ! mariusborza General Electronics Discussion 0 10-29-2006 04:20 PM
cnc controler gearcut General CNC (Mill and Lathe) Control Software (NC) 1 05-15-2005 10:46 AM
