Old 04-11-2007, 10:42 PM
Jedi is on a distinguished road
help with control power transformer
I need a control power transformer can anyone give me any help on if oter types will work because i cant find any that have the different outputs 12v and 110v. the old one is 1 PH 50-60HZ 4-0 VA
its for a King (bridgeport style) milling machine with outputs of
0 110 0 12 24 ground
Old 04-11-2007, 11:05 PM
Al_The_Man's Avatar
You could easily find two separate transformers if necessary, 110v secondary and 24v centre tapped secondary.
You would need to know where you need the most power, is that only 40VA or 4Kva?
Old 04-11-2007, 11:24 PM
It says on the transformer 4-0 VA so im not sure. Im looking for one that has these options.
Transformer for power supply for G100/G320 jamma General Electronics Discussion 3 09-22-2006 03:13 AM
Power Supply Transformer Question snooper General Electronics Discussion 4 07-30-2006 05:38 AM
control transformer to power supply? bobleecnc General Electronics Discussion 8 05-19-2006 09:42 PM
Microwave transformer built power supply TinkerDJ General Electronics Discussion 64 08-13-2005 07:19 AM
Connecting power transformer to 3 phase keithorr General Electronics Discussion 3 12-17-2004 02:52 AM
