Old 04-02-2007, 09:11 PM
joe aiello is on a distinguished road
rpm increase ?
I have a 5 hp 3 phase 230v 3450 rpm motor from a WADKINS moulder that I like to set up as a shaper with a dedicated 3-5" cutter (1 1/4" bore) with a specified height and setbacks(once setup,no change). This is direct drive, no pulleys. I like to run this in the 7000- 9000 rpm range; can I do this with a vfd? If so, which one? -- thanks ... joe
Old 04-03-2007, 04:54 AM
Zumba is on a distinguished road
No, an inducation motor cannot be sped up to 300% rated RPM by a VFD. You will need pulleys.
Companies such as Baldor make special "VFD-ready" motors that have better insulation, but even those can only be sped up to 200%.
how to increase output current siaug18 Stepper Motors and Drives 5 07-15-2006 01:09 PM
Do it with current or voltage increase? PMSM Stepper Motors and Drives 3 06-07-2006 02:18 PM
Stepper motor torque increase roni21702 Stepper Motors and Drives 3 04-03-2006 01:39 AM
Need To Increase Blend Radius. gcrudgington Mazak, Mitsubishi, Mazatrol 0 02-06-2006 11:12 AM
Can you increase threads strength? with glues sendkeys General Metal Working Machines 6 10-17-2005 10:48 AM
