Old 04-02-2007, 12:09 PM
cederron is on a distinguished road
Will this combination of drive - motor work ?
Hello,
I'm looking forward to do my first build, but being a naturally incapacitated guy with electronics doesn't help
I want to build a machine that could be upgraded, or at least, take the parts to build another bigger machine.
So, I have seen these drivers and motors :
DRIVER
Current adjustable from 2A to 7,8A (peak).
Motorvoltage 24-80 Volt
Suitable for bipolar motors up to 7,8A peak current. With 4,6, or 8 wires
MOTOR
1,8º (200steps).
torque 80 kg/cm
2,7 A./fase.
Ohm/phase 2.9
My main concern is that I have read in here that motors doesn't draw all the current all the time ( in this case 2.7A ), and you can see that the driver can deliver a minimum of 2 amps.
So if the motor draws less than 2 amps what will happen?
Are these motor/drives compatible?
Thank you very much.
Old 04-02-2007, 04:16 PM
Rocket154 is on a distinguished road
Why type of driver is this?
Old 04-02-2007, 05:31 PM
I guess you mean "what type of driver".
This one http://www.damencnc.com/damencnc.php...d=EN&idComp=23
Combination 4 Axis router Lathe wjfiles DIY-CNC Router Table Machines 3 04-16-2007 07:08 PM
Bridgeport Interact drive motor test - will this work? swarf_rat Bridgeport and Hardinge Mills 6 03-09-2007 06:11 PM
Will this brushless servo/drive/MP1000-THC combo work? wolfmetalfab Servo Motors and Drives 3 02-07-2007 07:37 PM
will my drive work with mach 3 Fabric8r Mach Mill 1 02-01-2006 06:46 AM
Servo Drive, will this motor work? beegner Gecko Drives 1 09-30-2005 12:42 PM
