  #13   Ban this user!
Old 04-01-2007, 03:39 PM
peternielsen is on a distinguished road
3phase vs single phase
Everyone has been correct when stating that HP is HP 1 hp =750 watts. You will probrably find that the factory is using a 3 phase motor with an inverter or vector drive. There is no loss in powere when these inverters have been properly installed. Most CNC equipment manufacturers use Inverter or Vector drives to control their spindles already if fact most of them are using single phase in and 3 phase out. Do not be scared of the performance that you will get out of the machine simply because it is only single phase in
  #14   Ban this user!
Old 04-02-2007, 09:58 AM
MrMagooo is on a distinguished road
Thank You all for very informative responses. Based on AnOldur's reply i will send in P.O. today for my 1st Fadal 2216. I was mistaken in original post, this machine is rated at 15 hp.
Could you please explain what it takes to go from 100amp main to a 200 amp?
As I do enjoy my roasts well-done.
Can I convert single phase motor to three phase? Jim Estes Phase Converters and VFD 30 01-24-2009 02:41 AM
Converting to Single Phase 4020 fadal chipsahoy Fadal 6 03-02-2006 10:27 PM
kasuga mill vfd single phase question mwp Phase Converters and VFD 3 11-22-2005 09:32 PM
fadal on single phase yeepman2 Fadal 6 02-07-2005 09:30 PM
Single phase Fadal nervis1 Fadal 9 12-24-2003 10:32 AM
