Old 03-23-2004, 07:47 AM
sp00k1e's Avatar
sp00k1e is on a distinguished road
strange motor problem
I machined some aluminium for the first time on my homebrew system lastnight and came across a strange problem. I was just jogging the machine to flatten the end, moving in the x axis i noticed that as the tool just touched the ali the y axis started to move, I dont think it is mechanical, so therefore it must be electrical noise, does anyone know where I should start looking, none of my leads are screened, but earthing the job didnt remove the problem. I am using Mach2 and Hans Wedermier's (?) control circuit.
I havnt noticed this happening with wood or plastic.
Paul
Old 03-23-2004, 10:00 AM
Urgundiz is on a distinguished road
well, if earthing the job does not solve the problem, maybe some kind of 'feedback' is going from Z to Y trough the material, are you able to guess a electric path between those elements? the problem repeats if you do a trial test with a non conductive (fake) tool?
hope it helps
/U
Old 03-23-2004, 03:54 PM
sp00k1e's Avatar
I think I have narrowed the problem down. I changed the parallel cable, that didnt make a difference. Then I started changing the speed of the router, this changed the speed of the spurious movements on the y axis, moving the router cable around the machine altered which motor was turning, lifting the cable upwards caused all the motors to move. It looks like the router is generating a lot of emi when cutting the metal for some reason.
Therefore my next question - what would be the best cheapest method of checking and removing the problem?
Maybe this is why B&Q were selling these units of cheaply.
Old 03-23-2004, 05:21 PM
Al_The_Man's Avatar
Paul, It sounds like you have a ground current loop, there may be slight ground leakage on your spindle that finds a path through the material if it is conductive. I would ensure that you have a good ground conductor from all your servo's and the spindle and make sure all these grounds and shields are connected to a common point and also your incoming earth ground should be connected to this point.
If you are operating from a PC, make sure the case of the supply is also connected to this point.
If you have any auxilliary dc supplies, I would make sure the DC common is grounded, unless the control instructions specify otherwise.
Al
Old 03-23-2004, 05:46 PM
sp00k1e's Avatar
I will try tomorrow to ground and shield everything, unfortunately the router is double insulated and therefore cannot be grounded.
Paul
strange bearing preload thread on ballscrew mxpro32 Benchtop Machines 14 03-22-2005 01:23 PM
Strange cutting pattern owhite Laser Engraving & Cutting Machines 4 03-13-2005 10:48 AM
strange bearing preload threads on ball screw mxpro32 Mechanical Calculations/Engineering Design 1 03-10-2005 08:07 PM
strange stepper heating Stevie General Electronics Discussion 5 05-21-2004 10:03 PM
