Old 03-22-2004, 10:55 AM
Al_The_Man's Avatar
Handy Little (Electronic) items
One of the most usefull little few-cent devices I keep on hand is the 2N7000. This is a FETlington, a small fet that replaces small bipolar Darlington transistors, The advantage is that the input is 5v logic compatible (max40v) and of course, high impedance of a FET and will handle 200ma max. drain current and operate devices (relays etc) up to 60v rating. I know there are chips that will do a similar job, but if you only need that one or two relays etc. it is quick and cheap.
Al
Old 06-19-2004, 08:24 PM
sol sol is offline
Gold Member
sol is on a distinguished road
Any particular manufacturer to buy from or avoid with these 2N7000s? Mouser has quite a selection and a cursory reading of the different data sheets reveals nothing that is that different as far as I can tell...Fairchild's are 9˘ each while Supertex's are 27˘, does higher price necessarily give higher quality here? Obviously it is not a money issue at these prices; I just want the things to work dependably.
http://www.mouser.com/index.cfm?&han...0&N=0&crc=true
Scroll down a bit for the listings.
Thanks for any info.
Old 06-19-2004, 08:52 PM
Al_The_Man's Avatar
I have been using fairchild for about 12 yrs now on a regular basis and do not recall a failure.
Al
Old 06-19-2004, 09:17 PM
sol sol is offline
Gold Member
Wow, That was a quick response!
Fairchild it is then.
Thanks!!
Electronic Viscosity damps bunalmis General Electronics Discussion 1 09-29-2010 04:49 AM
Need alist of all the electronic parts Cnc Wana bee General Electronics Discussion 0 03-17-2005 01:05 PM
Need alist of all the electronic parts Cnc Wana bee DIY-CNC Router Table Machines 0 03-17-2005 06:36 AM
Cutting "out" items from a sheet MrBean DIY-CNC Router Table Machines 12 01-03-2005 11:55 PM
Electronic circuit copyright. ynneb General Electronics Discussion 5 06-17-2004 10:56 AM
