I found a 48V power supply for about $40 but it is only 2 amps. Is it possible to modify it to give 8-10 amps? If so, how hard/expensive would it be? Could I make an easy change which would sacrifice some voltage for more amps? If I could get it to 40-42V and 8-10 amps that would be great. |
| i don't think it will work for that much change first you need to know how many amps the transformer will kick out then you can replace the bridge rectifier or diodes with ones that are rated for higher amps do a Google for power supply schematics |
| If you wired the supplies in series, you would have 48 Volts at 5 Amps. If you wire them in Parallel, you would have 24 VDC at 10 Amps. Jerry |
have a look at this thread http://www.cnczone.com/modules.php?n...warticle&id=27 there is more information on the front home page on www.cnczone.com Hope this article is of help , that is the problem with website so much information on here , i need to take a speed reading course to increase my reading speed from 20 words a minute to 1500 words a minute cheers |
| my company uses switching powersupply a lot. very nice size and very light weigh compared to the transformer type (3kg only). they come in 48v 10amp, and 48v 20amp i think the price is 180$ for the 10amp, i can send you few if anyone intersted. |
| Two more questions, then. 1) Is it more important to have more volts or more amps? I have now found a few identical 24V 7.2A power supplies. If I am understanding everthing that I have read in the zone I need around 32V 6A for my three motors, so I could wire two of these in series and be ok. However, I would like to be able to add a fourth axis later. This would require 42V 8A. Would the 7.2 A make that much difference? 2)If so, would it be possible to wire up three of these supplies in a combination of series parallel to get what I need? Again, maybe a stupid question. Thanks for all replies. |
adding another 12volt 4amp motor you will need a 12volt 10amp power supply if the motors are different voltages you will need a power supply for each voltage |
Now if you have 4 of those 24VDC power supplies... then your in business.
__________________ If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do? Steven |
#10
#12
Not always. It depends on the drives. Correct with Geckos or a Xylotex, but with a board like a Stepperworld, you'll actually need 2x the rated current per motor (full current for each coil of the motors).
| How'd you supply your power supply? | cnczane | DIY-CNC Router Table Machines | 12 | 08-28-2011 06:13 AM |
| Power Supply for High Amps | bprzybyl | General Electronics Discussion | 18 | 02-24-2007 03:01 PM |
| Power Supply from a computer power supply | jmytyk | General Electronics Discussion | 21 | 01-11-2006 03:56 PM |
| Howto find input amps, from output amps on transformer? | sendkeys | General Electronics Discussion | 7 | 07-14-2004 08:13 PM |
| second power supply amps? | sendkeys | Servo Drives | 0 | 07-08-2004 01:00 AM |
