Hi guys, I have imported AC Servo drives and motor (1KW each) for 3 axises mill. The power supply required to connect to the drive is 220 V 3 Phase (In oversea, they have transformer that convert from 380V to 220V 3 Phase). In US though, I was told that you SHOULD NOT connect industrial 3 ph-220V supply directly in as it may created noises and perhaps other unknown problems (Don't know if it true). So I was told that my solution is either to 1). Get 3Phase transformer 220V in, 220 V out (3Ph) , which by the way is not common to find!! 2). Get Filter? Reactor of some sort that would isolated it? (Any idea on this?) So for experience users out there, any help would be greatly appreciate it.Thank you in advance. Jeff C |
| The only thing I would check to see if it is 50hz, although in all probability it will have the tolerance to run on 60hz, Most AC drives or VFD's operate into a bridge rectifier anyway. Are you operating in a 3 phase shop? If so you probabally alread have a 220v transformer on the premises giving you the 220v, If you have any concerns, you can obtain 3 phase drive reactors from Hammond Transformers etc. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Al, Thanks again for the help. So your advice is that if it accept 220V 50-60Hz rating, then it shouldn't matter if you plug right into industrail 3Ph-220V? Also, I am not quite familiar with the use of REACTOR, can you be little bit more precise if you are refering to FILTER REACTOR at Hammond Transformers? Thank you |
| I see that Hammond no longer advertise 3 phase reactor chokes like they once did. These are an option, the advantage to these is they also have surge suppression in the way of MOV's as well as the Inductive Reactor. People like Mitsubishi & Fanuc use them. http://www.mtecorp.com/reactor.html You would only need one sized for all three drives. Like I said, in all probability you have a 220v 3ph local transformers already. Al.
| DFX is not imported correctly... | ihkim | GRZ Software- MeshCAM | 11 | 01-07-2010 12:57 PM |
| which 220v mig to get? | keebler303 | Welding, Brazing, Soldering, Sealing | 5 | 12-14-2006 10:06 AM |
| Yet another 120v to 220v | Konstantin | General Electronics Discussion | 4 | 02-24-2006 02:57 PM |
| 3phase servo retrofit | whiteriver | Servo Motors and Drives | 35 | 02-06-2005 10:27 PM |
| 3Phase motor, is it good. | Alan T. | General Electronics Discussion | 2 | 12-01-2003 12:01 AM |
