I am looking for some backup information and being that I am not a electrical engineer I need some help. Our machine recently blew the drive controller Talking with the manufacturer they are stressing that it is because of the voltage we have coming in. It is 240ac and are saying we should drop to 208ac. Although the manual and plate on the box says 220 plus/minus 10%. That is within the range of 240ac. So what we are think could a wire feed welder be cause the frequency or possible voltage spikes that will be causing it to go over the recommended power? Also how far should one keep a welder from a machine. Any suggestion will be great |
| Your machine says 220 +/-10 but your 240 supply is also going to be +/- something so it can go over 240 so you are right on the edge; as you have discovered. Welders can cause surges and spikes, especially big welders. I don't think it is a good idea to have things like welders on the same supply transformer as the CNC equipment. If you do not have any transformers inside your place then everything is on the same transformer that is somewhere outside. I would look into getting a buck-boost transformer for the machine. That will allow you to adjust the 240 voltage down toward 220 or 208 and the transformer will dampen surges and spikes from the welder. |
| New to TIG welding | johnsguns1 | Welding, Brazing, Soldering, Sealing | 10 | 03-01-2007 07:56 PM |
| Welding a Gap | Hellbringer | General Metal Working Machines | 12 | 06-06-2006 12:50 PM |
| CNC Welding Machine? | Kraig1 | CNC Plasma and Waterjet Machines | 3 | 09-17-2004 10:15 PM |
| welding jig | georgebarr | Welding, Brazing, Soldering, Sealing | 2 | 05-23-2004 07:47 PM |
