Old 03-13-2007, 03:11 PM
N4NV is on a distinguished road
12V regulator
I have an old mill that has a switching power supply with outputs of +5, +15, -15 and +24V. I need to get 12 volts. I purchased a 78m12 voltage regulator. When I test it on my bench I get 12.06v with an input between 14 and 16V. When I connect it to the Deltron power supply +15v, the output is 11.6V. I looked at the output with a scope and with the time set at .5uS I can see two saw tooth waves with min and max peaks about +- 1.5V. When I look at the +15 signal, it looks smooth. What is causing this? What is the best way to get 12v from this Deltron power supply?
Vince
Old 03-13-2007, 03:17 PM
Al_The_Man's Avatar
Did you put a cap. on the input and output of the regulator?
Old 03-13-2007, 03:19 PM
No, what size cap?
Vince
Old 03-13-2007, 04:03 PM
Al_The_Man's Avatar
Usually the spec sheet has recomendations, the minimum is usually .22µf on the input and .1µf on the output, I generally put a 1~10µf on the output.
Old 03-14-2007, 10:54 AM
pastera is on a distinguished road
You need at least some output capacitance, especially if you are driving a load with a switching regulator. Anything from 10uF to 47uF would be acceptable if all you want is to reduce the oscillations.
As long as the regultator is mounted close (<<6") to the power supply who shouldn't need any input capacitance but it won't hurt to add.
Going to a low dropout voltage regulator (IE: lm2940) with proper capacitors would give you a cleaner signal.
Aaron
Old 03-14-2007, 12:16 PM
Thanks, I will try a capacitor and see what happens.
Vince
Old 03-16-2007, 10:28 PM
I installed a 33uF cap to the output and a 22uF to the input of my regulator and the signal looks much better.
Thanks for all your input.
Vince
need high current regulator circuit tekno General Electronics Discussion 38 05-22-2006 09:00 PM
voltage regulator chips. Mcgyver General Electronics Discussion 9 12-19-2005 09:32 AM
PS Regulator freezer General Electronics Discussion 8 02-13-2004 10:48 AM
router speed regulator Hobbiest General Electronics Discussion 4 01-27-2004 05:36 PM
