first what does it mean if in bipolar p it says 2.8amps &in bipolar s it says 1.4 amps? what & how do you detrrmine if it is p or s? runing 2 of these motors plus another that says 6amps how many amp power supply do i need? thanks in advance greg |
| If it's an 8 wire motor, you can wire it either bipolar parallel or bipolar series. Parallel needs twice the current that series does. What kind of drives are you using. That will dictate the power supply requirements.
A bipolar drive is just a bipolar drive. You can wore the motors either way, but it doesn't matter to the drive. If you're running those motors on a Xylotex, you shouldn't need more than about 5 amps due to the limits of the drive. A non chopper drive might require up to 24amps for those motors. Depends on the particular drive.
| 2.5 amps per phase drive - 2.8 amps per phase bipolar motor ... | kochevnik | Stepper Motors and Drives | 6 | 10-22-2006 10:48 PM |
| How to set amps on driver? | Greolt | Stepper Motors and Drives | 16 | 09-02-2006 12:50 AM |
| Capacitors And Amps? | Oldmanandhistoy | General Electronics Discussion | 22 | 06-13-2006 02:20 PM |
| How many amps ? | bgolash | General Electronics Discussion | 1 | 03-09-2006 07:48 PM |
| Howto find input amps, from output amps on transformer? | sendkeys | General Electronics Discussion | 7 | 07-14-2004 07:13 PM |
