Page 1 of 3 123 LastLast
Results 1 to 12 of 28
Thread: 24vdc Power supply
    Gold Member thuffner3's Avatar
    Oct 2003
    Cincinnati, OH
    24vdc Power supply
    Hello Gang,
    I picked this unit up from e-bay the other day
    http://www.ferrus-power.co.uk/Custom...200/fs200.html
    The seller claims the unit is 24v but I can't seem to get any more than 16.3 to 16.5v. Am I doing something wrong in testing?
    Also I'd like to get a 12v leg out of this thing so I don't have to have an additional PSU in my Controller box.
    Can I achieve this with what I have?
    TIA.
    Neil
    Dec 2003
    I suggest you email the Manuf. if you don't have the spec sheet on this unit, it looks like it has multiple outputs, do you have it connected for 110ac? According to the description it has remote sense, which on most supplies must have one of the output voltages strapped across to it for fullvoltage.
    Al
    Nov 2003
    This might be stupid suggestion, but the unit is 220V or 110V. Is the selector switch in auto mode? Should be set to 110V.
    Oct 2003
    Cincinnati, OH
    No Pack,
    It depends on how you make your terminal connection from your power source. There are two connector, one for 110v the other or 220v.
    Neil
    Neil Jackson
    HAPPY NEW YEAR
    Dec 2003
    Neil, Do you have any hook up sheet at all? as according to the specs it has an enable/inhibit terminal, and the second page looks like it shows terminal 1 as the inhibit?
    Al
    Oct 2003
    Cincinnati, OH
    No, I haven't had the chance to get in touch with the manufacturer yet.
    Neil Jackson
    HAPPY NEW YEAR
    Oct 2003
    Cincinnati, OH
    Is pin number one as indicated in the picture at the bottom of page two? If so I was thinking this was the line connection for 220v. with (N) being for nuetral??
    Neil
    Neil Jackson
    HAPPY NEW YEAR
    Dec 2003
    It looks like there is two terminal strips (upper/lower), I was refering to the top strip term. 1 , it's a job to make out but it looks like INIH. I wonder if this is an industrial ATX style PC power supply as this would have all the PC required power supplies including PS-ON which is pin 14 of a regular ATX supply and has to be connected to common to switch the supply on.
    Al
    Oct 2003
    Cincinnati, OH
    I'll dig up my camera and take a picture of what I have.
    Neil Jackson
    HAPPY NEW YEAR
    Oct 2003
    Cincinnati, OH
    Pictures of terminal connections.
    It does look like the second set of terminals has INH as a number 1.
    Oct 2003
    Cincinnati, OH
    More
    another shot
    Oct 2003
    Cincinnati, OH
    That's the best I can do with the camera. Can't seem to get the right lighting. But I can see that terminal #1 of strip #2 is INH. 4 & 5 of Strip #1 are for L N and gnd.
    Neil Jackson
    HAPPY NEW YEAR
  • Page 1 of 3 123 LastLast
    1. How does a power supply work.
      By ynneb in forum DIY CNC Router Table Machines
      Last Post: 07-27-2011, 10:40 AM
    2. Diy Power Supply Choices
      By berin in forum DIY CNC Router Table Machines
      Last Post: 07-13-2005, 04:47 PM
    3. 5 Volt Power Supply Tripping
      By murphy625 in forum General Electronics Discussion
      Last Post: 02-27-2005, 10:05 PM
    4. Is this power supply rating adequate?
      By jerryrigge in forum General Electronics Discussion
      Last Post: 11-25-2004, 11:06 AM
    5. Choosing a Power Supply for Retrofit?
      By pfeist in forum General Metal Working Machines
      Last Post: 05-23-2004, 11:36 PM
