Old 02-28-2007, 02:02 PM
aegfurn is on a distinguished road
no logic x/y machine
I am building a paint spraying machine. The spray head needs to move in the +y direction to the end of travel. Then the x needs to advance 4" or so. Then -y to the end of travel, x advance, then start over.
Is it possible to do all this with relays and leave the computer out of it?
Thanks,
Pete
Old 02-28-2007, 03:03 PM
Al_The_Man's Avatar
What you are describing is a point to point machine, and it can be done fairly simply as you suggest, I would look at a Smart Relay like Siemens Logo, others re-label the exact same item, Idec, Omron etc.
It is fairly simple logic programming and you do not need special software.
As to the motor control, If precise positioning is not required, Then anything from switching a DC motor on/off or set up a train of pulses with a simple 555 generator oscillator to operate into stepper drives.
The steppers may give you close to exact positioning as when you turn them off they stop almost instantly.
Do you use BOOLEAN logic when searching the web? widgitmaster Polls 18 06-02-2006 11:10 AM
5v for logic... WilliamD General Electronics Discussion 4 02-10-2006 04:52 PM
Ladder logic Chris Roth Deckel, Maho, Aciera, Abene Mills 4 12-26-2005 10:29 AM
need help with simple logic circuit rebrumm General Electronics Discussion 7 10-30-2005 02:26 AM
'tolerance' for STOP logic squarewave CamSoft Products 6 09-11-2005 11:34 AM
