I have a feeling this question may get ignored but I hope not. Simple question; are these capacitors suitable for a PSU for stepper drives? http://www.rapidonline.com/netalogue/specs/11-1534.pdf Main information at bottom of the sheet and if they are ok and you are from the UK then well worth a look at only £1.76 each. Any help as always very much appreciated thank you, John |
| They seem to have decent ratings, and they should be quite suitable for a PSU IMO, in fact they show this in the application.
| Wow Al the man that was quick; my opinion of you just gets better and better. While I have your attention I have an other simple question for you (not for me very electronically challenged) If I have a toroidal transformer rated say 300va which has two secondary windings and I wire then series what current can I get; is it 300va or 150va? I did spend a lot of time looking on this forum for the answer but found nothing. Thank you very much for your time. John |
| I use C= I x 80000/V = C in uf John |
| The VA does not change, This is basically the power rating of the Txmr. The current capability will however so whatever the final voltage is decides the max current available from the winding, IOW divide the VA by the secondary voltage to arrive at available current. Al.
| Suitable Threaded Bar | gmc6711 | Linear and Rotary Motion | 7 | 09-05-2006 11:38 AM |
| Is this Spindle suitable for CNC Mill ? | rrossey | General Metal Working Machines | 2 | 04-21-2006 08:47 AM |
| Need a suitable machine | Moesian | Mechanical Calculations/Engineering Design | 0 | 08-14-2005 11:49 AM |
| Would this be suitable | Hasher | DIY-CNC Router Table Machines | 0 | 06-18-2005 10:23 PM |
| the suitable software | mounir | General CNC (Mill and Lathe) Control Software (NC) | 4 | 01-28-2005 12:44 PM |
