Results 1 to 11 of 11
Thread: Compaq Power Supply.. Anyone get one to work?
    May 2006
    I have a few power supplies from old Compaq EN450's.
    Label says they are 200W supplies.
    I followed the link to convert an ATX power supply (listed elsewhere in this forum). My power supply does not use the same colors for some of the values.
    Here is what I think I have
    Red +5 volt
    Black ground
    2 brown marked at 3.3v
    1 brown unmarked
    Orange +12V
    Blue -12v
    Purple fan-off
    White SO?
    Green 5VA grey Auxgnd
    I have a 10ohm 10watt resistor connected to one red and one black wire.
    I do not know which wire is the Sense wire that need to be tied to the 3.3v to make this thing come on.
    I know the supply is good, it worked before I cut the ends off.
    Any assistance would be greatly appreciated.
    Thank you in advance
    Eric
    Registered Genguy's Avatar
    Nov 2005
    If you still have the connectors that you cut off, they have terminal numbers on them. You can use the numbers to figure out what the function of each wire is. Here is a pinout diagram.
    May 2006
    This power supply has only one large connector.
    Is seems to be close to an ATX power supply, but Compaq seems to do things thier own way.
    I cannot seem to get this thing to power up now.
    Nov 2005
    I found this pinout posted on another forum. Maybe it will be closer to what you have.
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    ive done it with a compaq but i can t remember 100%
    if it has a green wire connect that wire to the black neg wire and it should power up
    Jan 2004
    GTA CANADA
    stolen from
    http://www.hwkb.com/Uwe/Forum.aspx/h...in-motherboard
    Quote--------------------------------------------------------
    Another instance of "Proprietary hardware." Does anyone know the
    >voltage or purpose of each lead on such a Compaq PS versus a standard
    >PS? I was wondering if such a standard supply could be modified to the
    >Compaq requirements? Such as the extra leads on a Compaq might simply
    >be additional leads with an already existing voltage elsewhere on the
    >standard PS (i.e +3.3 volts).
    I tried modifying one once, did what seemed appropriate by connecting the
    rails of a standard ATX to the proprietary Compaq wiring harness, but it
    didn't work... I even supplied the Aux. 3VSB power (via a 2nd external
    power supply) that theirs has but it STILL didn't work. I might've gotten
    it to work if I had the Compaq motherboard too but I didn't, the fellow
    with the system was hundreds of miles away.
    Anyway, here's the pinout on the original unit I had, compared to a std
    ATX. The terms such as "fan_sink" and "onstby" aren't standard terms but
    were silkscreened onto the Compaq PSU PCB itself.
    Pin # STD ATX 12V Compac 5320US
    <1> +3.3 VDC +3.3 VDC Brown
    <2> +3.3 VDC +3.3 VDC Brown
    <3> COM COM Black
    <4> +5VDC +5 VDC Red
    <5> COM COM Black
    <6> +5 VDC +5 VDC Red
    <7> Com Aux Gnd (from aux board) Grey
    <8> PWR ok N/C
    <9> +5V SB +5 (from aux board) Turquoise
    <10> +12 VDC +12 VDC Orange
    <11.1> +3.3 VDC +3.3 (from aux board) Pink
    <11.2> 3.3V sense
    <12> -12 VDC Fan CMD White w/ Red Stripe
    <13> COM +3.3 VDC Brown
    <14> PS - On +5 VCD -12V? Blue (-12V)
    <15> COM COM Black
    <16> COM Power On White (ONSTBY)
    <17> COM COM Black
    <18> -5V COM Black (2nd wire, black
    RTNRS)
    <19> +5 VDC COM Black
    <20> +5 VDC +3.3 VDC Brown
    <21> ------ +5 VDC Red
    <22> ------ +5 VDC Red
    <23> ------ +3.3 VDC Sense Brown (3VRS)
    <24> ------ Fan_sink White w/ Blue Stripe
    maybe...
    Jan 2006
    It is the green wire that you connect to any of the black ones. But sometimes you have to put a load on them to get them to power up. Did you cut all the connectors off? If not just hook up an old hard drive or old CD ROM and I bet it powers up.
    Oct 2005
    canada
    Quote Originally Posted by davesaudio View Post
    i just upgraded my compaq power supply recently and there is a patch harness that comes with after market supplies
    snap it in and go
    May 2006
    I tried to tie the green wire to a black wire and no good.
    I have a 10ohm 10watt resitor between one of my red wires and one of the black wires. Still no go.
    Dertsap.. You speak of a patch harness?
    Where did you find that?
    Oct 2005
    canada
    Quote Originally Posted by EGropp View Post
    it came with the new supply
    Jan 2006
    I'm not sure if you need to use a red 5 volt or a red and yellow 12 volt. I know a hard drive will work I'm currently using one now that will only power on when I hook up a hard drive. Here is link that will maybe explain better.
    http://www.directron.com/2powersupplies.html
    1. How'd you supply your power supply?
      By cnczane in forum DIY CNC Router Table Machines
      Last Post: 08-28-2011, 06:13 AM
    2. How does a power supply work.
      By ynneb in forum DIY CNC Router Table Machines
      Last Post: 07-27-2011, 10:40 AM
    3. Could this work as a cheap power supply?
      By phantomcow2 in forum General Electronics Discussion
      Last Post: 03-05-2006, 05:10 PM
    4. Power Supply from a computer power supply
      By jmytyk in forum General Electronics Discussion
      Last Post: 01-11-2006, 03:56 PM
    5. Power supply help
      By osdhillon in forum General Electronics Discussion
      Last Post: 06-01-2005, 02:32 PM
