Results 1 to 2 of 2
Thread: Optical Encoder Differential Line Driver
    Feb 2004
    Lightbulb Optical Encoder Differential Line Driver
    I'm setting up a Rutex servo system so I have the option of TTL or Differential encoder inputs.
    Having only TTL encoders at the moment I thought I would try and make a convertor. (I'm paranoid about noise)
    I figure if I mount this in a little guy at the encoder it may do the trick.
    Since the 26LS31 is quad I killed 2 birds with one stone and made an extra output for a future DRO I'm dreaming of.
    Any suggestions? Think it will work?
    Is this a good thing to use on other circuits if I make a receiver?
    Chris
    Attached Thumbnails Attached Thumbnails Optical Encoder Differential Line Driver-control_panel8.jpg
    Mar 2003
    Israel
    It looks OK.
    Just check if your encoder output can drive 2 26LS31 inputs. I used similiar setup in the past, but had to put additional driver.
    Probe
  1. encoder issues
    By rutexus in forum Servo Drives
    Last Post: 05-21-2006, 07:49 PM
  2. 8830 Line driver for encoder output?
    By murphy625 in forum CamSoft Products
    Last Post: 03-29-2005, 02:15 PM
  3. easy tacho or encoder: cny70 reflective optical sensor
    By gcamlibel in forum General Electronics Discussion
    Last Post: 10-12-2004, 03:38 PM
  4. Fun with floppy stepper and driver
    By Konstantin in forum General Electronics Discussion
    Last Post: 03-08-2004, 02:18 AM
  5. Optical Limits
    By IndHobby in forum Product and Manufacturer Announcements
    Last Post: 02-10-2004, 01:51 AM
