A bit OT need a variable speed control for a 12V DC brush type permanent mag motor. Motor is rated at .4A no load to 3.4@ max 7200RPM Planning on using this on a 2 axis CNC controlled Ox/Acet burning table for manual torch height control. Any help much appreciated.
__________________ If it works.....Don't fix it! |
| There are a number of 'model train throttles' that will readily do what you want to do. However, to retain torque, you're probably better off with a PWM based throttle. Do a web search for an NE544 IC. THis is a servo driver IC that has been used to make PWM bidirectional speed controllers for a number of hobby uses over the years. If you're electronic literate, you can create a wein bridge oscillator to make a saw tooth generator with two stages of a 324 op amp. You can then feed the saw tooth into a comparator circuit made from the remainder of the 324 and drive a mosfet (IRFZ40 or 44). The whole circuit takes residence on half a business card. |
| CNC Controlled Spindle motor speed control | gregmary | General Electronics Discussion | 13 | 02-27-2009 07:01 PM |
| BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? | peter.blais | Bridgeport and Hardinge Mills | 9 | 08-08-2006 03:29 AM |
| speed control for this motor | ZipSnipe | General Electronics Discussion | 7 | 08-02-2006 10:28 PM |
| need speed control for single ph motor | FLUTE HEAD | General Electronics Discussion | 4 | 10-06-2004 10:35 AM |
| AC Speed Control | georgebarr | General Electronics Discussion | 7 | 01-06-2004 07:33 PM |
