Old 02-03-2007, 12:15 PM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Question LED Voltage
I'm using an old PC case as my control box and it has a few LED's on the front. Thought I might connect them to the various power sources so I could see if one wasn't on, or working.
My question is what is the typical voltage to little LED's like these?
I have 5V DC and 28V DC I would like to monitor. If this is too high of a voltage to apply to the LED's what size resistor would I need to drop the voltage down?
Old 02-03-2007, 12:34 PM
Al_The_Man's Avatar
LED's are current operated devices, (forward biased diodes) you need a series resistor.
A rough guide if you don't know the specs. is 330ohm for 5vdc and 1200 ohm for 24vdc.
Old 02-03-2007, 12:52 PM
Mr.Chips's Avatar
Gold Member
Thanks AL,
I pick some up and give it a try.
Old 02-03-2007, 01:10 PM
Al_The_Man's Avatar
BTW if you get the polarity wrong, it won't screw anything up, just that the LED won't light.
Max voltage tekno PicStep Controllers 3 04-02-2006 05:49 PM
Lowering PS Voltage id 10 t General Electronics Discussion 3 12-13-2005 01:51 AM
Operating Voltage jhwatts Hobbycnc (Products) 6 10-13-2005 11:29 AM
Stepper / Voltage ckrantz Stepper Motors and Drives 10 10-03-2005 07:02 AM
PSU Voltage seems high. mnewsholme Hobbycnc (Products) 10 04-26-2005 03:26 AM
