Old 02-03-2007, 10:23 AM
mackeym is on a distinguished road
AC Servo Motor lead filtering
I recently got a CD series Kollmorgen brushless servo drive. The manual recommends filtering the power leads from the drive to the servo motor. Ferrite cores are for the differential mode filtering and ferrite toroids are for common mode filtering. My question is, can you use both types of filtering on the lines (or should you pick one and just filter that type of noise)? I would think it's ok to use both a core and toroid in series (if this shouldn't be done, i would think the manual would have warned about this)...i thought i would ask here anyway.
Old 02-03-2007, 10:44 AM
Al_The_Man's Avatar
You can use both if you wish as they are generally non invasive as to the feed to the motor itself.
In the past I have used the method recommended by AeroTech, I obtained some large ferrite toroid cores off ebay and wound as many turns possible of each conductor on the single toroid, and placed it as close as possible to the motor.
Do not include the ground conductor.
Lead screw lube amount. servo belt replacement bob1112 Linear and Rotary Motion 2 11-24-2006 06:59 PM
Making a coupler between motor and lead screw nikolatesla20 Mechanical Calculations/Engineering Design 8 07-30-2005 01:05 PM
Problems aligning motor with lead screw. SCCoupe DIY-CNC Router Table Machines 11 02-15-2005 06:33 PM
Minebea Lm23 Motor Lead Color Code A. Shuford General Electronics Discussion 3 09-05-2004 10:17 AM
coupling motor to lead screw ideas? fyffe555 DIY-CNC Router Table Machines 4 09-15-2003 11:18 AM
