Old 01-29-2007, 05:31 PM
Fluxion's Avatar
Fluxion is on a distinguished road
Can I add more LED's to CPU front panel?
I have a home built CNC router with a PC based controller. I have build a cabinet to house the cpu case my stepper drivers and power supply. I have added a power switch and reset switch and relocated both LED's to a control panel. I would like to keep the LED's in my case working, how can I add another LED to a computer front panel display? I know I can't just hook another up in parallel. Is there an easy way to do this? I know its trivial to not have the LED's illumineated inside my cabinet but I actually have another place I could use the same solution.
Old 01-29-2007, 10:10 PM
vladdy's Avatar
vladdy is on a distinguished road
Actually, you probably can just hook up another in parallel, kind of..
Get two that together have the same approximate current draw would be the best way..save the old ones for retrofit later on..
or just try adding another in parallel and see how much they 'dim' as a a pair, you can get very lower power draw leds currently,
did a quick check on digikey, 5ma for $0.18, 1.5ma a bit more..most cpu leds that I have looked at [not recently, though] were 20 to 25ma, so a 5ma wouldn't dim the pair very much at all..
enjoy..
Store front aluminum channel ? Bzooka Open Source CNC Machine Designs 8 05-04-2010 03:40 PM
My DIY control panel DennisCNC CNCzone Club House 6 10-02-2006 10:24 PM
Picstep front copper backward? obscurity PicStep Controllers 1 06-05-2006 06:56 PM
Panel Meters beausdn Gecko Drives 0 08-11-2005 11:35 PM
CNC-Zone Mug with logo on front and back samualt Suggestions for the CNCzone.com site. 1 07-29-2004 08:00 AM
