I ran into a problem today when testing my new geckodrive 320's and servo motors when I found out my laptops parallel port is using 3.5v and geckodrive 320's are made to run with 5v. Since I can't tell just by looking what/if a breakout board is going to do any level shifting for me I'm stuck =>... be nice if there is a relatively cheap circuit I can craft to accomplish this even if its on a breadboard. My rather limited electronics knowledge is telling me I may be able to use a regulated voltage source and 555 timers but there must be a better solution. Maybe an opto that can run on 3.5-5v so it would work with both 3.5v and 5v computer parallel ports. Just had a thought... isn't there a parallel port plug available somewhere that does this using a wall power supply? So I put this plug on my computer than my cable into the plug and voila 5v logic? |
| i didnt really think about it at the time, but i saw a usb to parallel adapter at wall mart the other day when i went to get a usb to serial adapter to run my machine. I know the voltage at the usb port is 5 volts so its completely possible that it may work for you.
__________________ Lemon Curry?? |
| erase43 - I did a search for these adapters at www.tigerdirect.com they are not very expensive but a search for "usb parallel port" at www.machsupport.com suggests they will not work. phantomcow2 - A few months ago I purchased a ready made CNC system for my TAIG and had to return it because it would not work. I know now that it is because the designer left out a breakout board with level shifting. |
| you can use a few 2n3904 transitors to boost the level, it won't be isolated but it's cheap and you can get the parts at Radio Shack. A 4.7k base resistor and a 470-1k pull up resistor to 5 volts on the collector. This would draw about 500uA from the port and deliver 2-5mA at TTL levels. Aaron |
| Signal voltage converter? | gotis | General Electronics Discussion | 4 | 10-28-2006 06:32 AM |
| Getting analog signal from pc | roni21702 | Computers and Networking | 1 | 06-15-2006 01:34 PM |
| Booster for spindle? | Corvus corax | Mechanical Calculations/Engineering Design | 11 | 12-04-2005 02:34 PM |
| Using the err signal | FrankdB | Servo Drives | 1 | 03-30-2005 06:10 PM |
| code 86 dr signal off | CBNDude | Mazak, Mitsubishi, Mazatrol | 13 | 03-25-2005 01:08 PM |
