Old 01-25-2007, 05:51 PM
Micro Rotors is on a distinguished road
Allegro SLA7072MR Chips?
I am wanting to make a driver board for a CNC router and a U2 mini mill and a CNC foam cutter and I have 4 of these chips (Allegro SLA7072MR). Will they work?
Bill
Old 01-26-2007, 11:55 PM
Bill
Old 01-27-2007, 05:35 AM
epineh is on a distinguished road
Looks like they will, unipolar drivers, up to 3 A and support microstepping. You just have to make up a PCB and you are on your way.
I assume you have read a little on this thread...
http://www.cnczone.com/forums/showthread.php?t=24699
Same manufacturer, different chip that uses external N-channel Mosfet's to drive larger motors, I am looking at something similiar as those guys, mainly as it's bipolar and supports higher current configuration's (externally from the chip though...)
Let us know how you go.
Russell.
Old 01-27-2007, 01:18 PM
epineh,
Thanks for your reply!
No, I will start reading it right now. I am new to making a setup like this and I have not tried soldering IC chips such as the A3986. Is there a tutorial on driver boards out there that explain their function or a tutorial on putting a kit together?
Bill
Bill
Old 01-27-2007, 04:26 PM
No tutuorials as far as I know, but the thread I mentioned will give you an idea of the process involved. One of the biggest hurdles is the soldering the chip and making the PCB to start with, I don't have any experience with either (yet) but I have started on the PCB side of things...
http://www.cnczone.com/forums/showthread.php?t=30951
And for soldering the SMD components I was thinking :
http://www.engadget.com/2006/03/07/h...oldering-iron/
It is all a work in progress but I will have a build log of it around here somewhere once it is up and running.
Russell.
Old 01-28-2007, 08:01 PM
phantomcow2 is on a distinguished road
I believe Dave from HobbyCNC uses those chips. They are Allegro at least.
I would just buy his board rather than make one, It is pretty tough to beat the price
http://www.hobbycnc.com
Allegro A3979 Stepper Driver Tuning jkpugh Stepper Motors and Drives 7 07-06-2009 03:13 PM
Allegro A3986...Stepper Translator slp_prlzys General Electronics Discussion 2 06-07-2009 01:59 PM
Sanken Allegro Wonder Chip zarijebul Stepper Motors and Drives 1 10-13-2006 03:59 PM
Source for Allegro 5804B IC's - Qty 10??? FrankG Open Source Controller Boards 4 01-30-2005 05:11 AM
Cook your chips to make more chips :) ToMMY2ooo Bending, Forging,Extrusion... 3 09-07-2004 01:38 PM
