Old 01-05-2007, 02:30 AM
skmetal7 is on a distinguished road
digital calipers
I was wondering how a digital caliper/micrometer works. anyone ever have a thought about this? does it work on some kind of varying resistance on the slide? and how does it measure so accuratly without losing its place (of course when there are no metal chips inside, i hate that).
Old 01-06-2007, 05:23 PM
edo edo is offline
edo is on a distinguished road
Question
I couldn't figure it out either. I picked up some 6" ones from Harbor Freight (recent coupons advertise them for $6.99). I took one apart hoping to adapt it to my router table. I wanted to remote the display and embed it in the top of the table and hook up whatever it used for measuring distance to the router, but I couldn't separate the two parts. The PCB that the LCD display is on has a bunch of small traces along it that contact the sliding the bar. The sliding bar is composite fiber and doesn't have anything special on it.
If anyone knows, I'd still like to figure out how to mount one on my router table.
Old 01-06-2007, 07:22 PM
Joey is on a distinguished road
I bought a digital vernier scale, the type you can bolt onto a machine slide, for example a quill feed. The orientation of the quick reference scale was wrong for what I wanted ie. the graduated ruler 0 to 150 needed to be reversed, so I thought I`d try prise it apart from the slide.
I lifted the scale slightly and noticed there were what seems to be circuitry lines
printed on the underside of the rule scale which is just held in place with a sticky adhesive. I didn`t know if the reader head would screw up having to possibly read back to front, so I never took it off.
Old 01-06-2007, 08:29 PM
One of Many is on a distinguished road
These scales are basically an absolute encoder, but do have incremental capability.
This link should explain it quite well
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 01-07-2007, 10:24 AM
edo edo is offline
DC - The link was great in explaining how to pull the data, thanks.
But I still don't understand how it reads movement across the PCB traces, or as Joey said, the circuity lines.
Old 01-07-2007, 11:28 AM
phantomcow2 is on a distinguished road
I had it explained to me once. I believe it has something to do with inductance
This is a good thing to research
NC Cams is on a distinguished road
The device is purely a digital counter.
If you get hold of a Red Lion counter catalog, they have "counters" that can count stuff and/or be used to make digital scales to record length from turning screws or moving devices.
The thing being "counted" is either an optical reflection or an electronically sensed edge or perhaps a magnetic flux change.
Again, the Red Lion catalog provided me with an explanation that facilitated an understanding of the technical processes involved.
Old 01-07-2007, 11:40 AM
Al_The_Man's Avatar
AFAIK it uses the Inductosyn method, I believe first developed by Farrand.
http://www.ruhle.com/
You don't see the linear machine scales much anymore.
Do a search for inductosyn theory, should show how.
Mitotoyo make a cheap linear DRO read out on this principle.
http://www.ruhle.com/operation.htm
Old 01-07-2007, 02:02 PM
Sorry about that. I thought it included comprehensive information I read a long time ago.
One explanation
One Patent
The guts
There are several different encoding formats of this type of scale.
I have interfaced the Digimatic code with the Parallax SX48, but have not worked with the output of these chinese scales yet. The chinese scales seem to pass through continuous data updates for external use. While the Digimatic output must be requested and has a specific embedded data format.
DC
Old 01-07-2007, 02:33 PM
Al_The_Man's Avatar
It apears they adapted the inductosyn method but replaced the inductive coupling method with a capacitive one.
  #11   Ban this user!
Old 01-07-2007, 05:48 PM
wow this is way more complex than i thought! cool though. thanks for the explanation and links.
  #12   Ban this user!
Old 01-07-2007, 08:31 PM
edo edo is offline
I too appreciate the links. Who'da thunk there was "stuff" under the ugly Cen-Tech Made in China sticker on the slide bar.
