Old 02-10-2004, 07:19 PM
Gold Member
creative_mind is on a distinguished road
What is Volt-Amp?
I have a transformer which it's labelled 24 VAC and 40 VOLT-AMP. How do I figure out the current rating mathematically?
Thanks.
Old 02-10-2004, 07:25 PM
Stevenpats is on a distinguished road
40VA/24Volts=1.6 amps or so,VA is just another term for power similiar to watts. Larger transformer are usually rated in KVA.
Steven
Old 02-10-2004, 07:27 PM
Gold Member
Looks like power in watts is about 65% of VA.
Am I correct?
Old 02-10-2004, 11:20 PM
Al_The_Man's Avatar
The reason the wattage in a transformer is not the direct product of the voltage x current as it is in a DC or AC resistive circuit is that a transformer is an inductive device, so the voltage wave form leads the current wave form so they do not exactly peak at the same time. So in order to calculate the actual wattage rating this amount of lead has to be known and is known as the power factor, and varies on the device and the operating conditions etc.
An extreme example would be a perfect inductance where the phase shift was 90deg. Voltage would be applied and current would flow but wattage or power would be zero.
In circuits with a poor power factor, a capacitor can be added to compensate for the phase shift because in a capacitor the voltage LAGS the current.
Al
Old 02-11-2004, 03:59 AM
limbo is on a distinguished road
Stevenpats is right, its not 65%. Its 24V, 40 Watts. Maybe you confused the 24Vac with watts?
John
West Amp Servomotor help johnd Servo Motors and Drives 9 12-11-2008 03:20 PM
5 Volt Power Supply Tripping murphy625 General Electronics Discussion 13 02-27-2005 09:05 PM
Need a low cost 4 amp, 48 volt, stepper drive Mini Miller Stepper Motors and Drives 19 12-15-2004 01:29 PM
servo and amp question cncfoam General Electronics Discussion 2 01-19-2004 04:25 PM
200 Oz-In 6.5 Amp Bipolar Parallel motomitch1 General Electronics Discussion 9 05-06-2003 02:07 PM
