I picked up a transformer from Grainger today. I'm building the hobbycncpro kit and was trying to get a transformer that was rated at 24vac 10a. The transformer they had is rated at 24vac 40a. Will the 40 amps be too much or will the extra amps just be unused overhead? i'll be running 3 200oz steppers and driving the hobbycnc board. Thanks, Scott |
| Just for reference, what was the part number for the transformer from Grainger? 120 Volt I assume? I ended up using one from MPJA.COM ‘7846 TR’ ( http://www.mpja.com/productview.asp?product=7846+TR ) on a HobbyCNC (pre Pro) board. After rectifier & caps I’m getting 31.5 VDC, not quite the 33 calculated but useable.
__________________ Mike_L When I was younger I thought I knew EVERYTHING, NOW, the older I get the more I find out I don’t know! |
| This question came up before http://cnczone.com/forums/showthread...ight=va+factor The reason is a transformer is an AC device and depending on the load, the peak current and peak voltage may not coincide, therefore if the current and voltage are not in phase because of this, you would need a larger transformer. For the average person building a DC power supply, it is usuall to use A x V for power rating of a transformer, and not be concerned with power factor etc. Al.
| Sorry but that transformer is rated 40 VA Not 40 Amps that does come out to 24 Volts at 1.6 (1 & 2/3) Amps the one I posted in the MPJA.com Link IS 24 Vac @ 10 Amps $17.99 + shipping You Could remove and replace the secondary from a surplus Microwave Transformer, but that is hardly worth the trouble for this (24V 10A) kind of output.
#11
OK, Bimmerkc1 (Scott) had PM'ed me about the MPJA.COMTransformer I had posted about. He had some wiring questions and I did not see a way to attach a picture to A PM reply, so I'm posting this diagram here for Scott and others. You Guys who know more than me are welcome to reply, just don't SMACK me too hard with that chair.
