Hello everyone.
Iam sure many of us raided copiers in search of steppers and other useful stuff. I have this flea market guy that can supply some unipolar steppers with the driver module attached to the mounting frame, the stepper is a Sanyo Denki StepSyn 3.25A and the driver module is based on a STK672-050. As I ve learned from the driver pdf, its is a microstepping (1/16) driver 3A max and while I am trying to figure out how my particular driver board is configured I would like to know if any of you have experience about this module or similar.
http://www.ortodoxism.ro/datasheets/...STK672-050.pdf
This is a small excerpt from the pdf:
One of five drive types can be selected with the drive
mode settings (M1, M2, and M3)
—2 phase excitation drive
—1-2 phase excitation drive
—W1-2 phase excitation drive
—2W1-2 phase excitation drive
—4W1-2 phase excitation drive
• Provides four freely selectable modes for the vector
locus during microstepping drive: circular mode, one
inside mode, and two outside modes. |
My question is if the terms W1-2 or 4W1-2 are meaningful outside Sanyo or those are Sanyo's terms.
Another question: what are the microstepping modes: circular, one inside, and two outside?
This modules use a clock generator to supply the steps and I believe it uses the enable pin to spin it at constant speed and the directional input for the CW/CCW changes, so my idea is to bypass the CLK signal and use Step output from Mach3 to drive it like a regular Step/Dir module.
There is this thing though, from the pdf "CLK Minimum pulse width: 10 μs" makes me wonder if Mach3 will be able to drive it since the "Motor Tuning" in Mach only allows 1-5uS.
Since these modules can be acquired very cheap the temptation for a microstepping module is big.
Thanks.
Konstantin.
