Hi I have recently finished building my Steel Router with a working range of 920mm x 600mm x 140mm and it worked fine except that the motors continually lost steps while cutting even at quite slow speeds. The general opinion on this forum was that the 1 nm Motors that I fitted were not powerful enough for my size of machine. So I have now bought some new 4.5nm motors and electronics to 'beef' up the machine. The Guy that supplied my original electrics wanted £600 + all my old electronics and wiring returning to upgrade to a more powerful setup. So I decided to source the parts myself. Here is the list of the new parts that I have bought from Motion Control :- 2 x 8 wire 4.5 nm Stepper Motors for the X & Y Axis 1 x 6 wire 4.5 nm Stepper motor for the Z Axis 3 x MDS542 4.2amp Driver 2 x 42vDC 280w Power Supplies (The guy recommended that I bought two to be on the safe side, and to 'gang' the outputs together) 1 x Breakout Board 1 x 4 Relay board to drive my Router and Dust Extraction system. The reason for the different motors is that they only had 2 in stock, the guy said the 6 wire motor would be fine for the Z Axis. This weekend I would like to get the parts up and running on the bench, and I could do with some help from the electrical Gurus that are on this site ![]() Electrics are not my strong subject and bring me out in a cold sweat so please be gentle with me ![]() I do have a multi-meter available if required. Now onto the questions :- 1) The X & Y Motors have 8 wires, how do I wire these into the A+,A-, B+ B- on the driver. 2) The Z Motor only has 6 wires, one of these is just a 'bare' wire with clear insulation on it. How do I wire these into the A+,A-, B+ B- on the driver. 3) On the PDF file attached for the driver it shows a typical wiring diagram and it shows 3 x 270 ohm resistors, are these already fitted internally, or do I need to add these? 4) In my enclosure I have only 240v AC and 42v DC available, what is the best method for me to power a 12v cooling fan? 5) I have my original box and working Mach2 file to get all the pin numbers for the limit switches etc. What pins on the parallel port would I use to switch the relay card on & off? 6) What pins do I use on the Breakout Board for connecting the Driver PUL+, PUL-,DIR+, DIR-, ENA+, ENA- Thanks in advance, it is very much appreciated. Andy |
| Hi Andy, I am by no means an electronics gurus ( could not be further from the true) but I have experience with the MSD556 drives. You may like to read through this thread and see wiring diagram. http://www.cnczone.com/forums/showthread.php?t=17857 1 / you should have some info with the stepper explaining which wire is for which phase; if you don’t have the info you need to get it. If this machine is for wood then I recommend you wire bipolar parallel. 2 / Same again you need wire colour code information before you can wire it to the drive. 3/ Yes they are fitted internally and the drive is also optically isolated. 4/ I would just use a 12v adaptor but others may give you better advice. 5/ Not sure would need to find information. 6/ See wiring diagram in suggested thread. Hope this helps, John |
| Just read your post again; I presume you checked the printer port when investigating your lost steps? The reason I ask is I had a problem with loosing steps and after exhaustive investigation it turned out to be my printer port; changed PC and the problem went away. Btw they are some beefy stepper you got there. John |
![]() I did not get any info with the stepper motors which is why I attached a picture showing the label...... I thought I read somewhere that you could determine which wire was which with a Multi-meter??
![]() Andy |
I built the machine for my business, and once it is reliable it will be running most days, so I made sure the motors were upto the job! Andy |
![]() I will get in touch with them on Monday to see if they have any more info available. Andy |
#11
| The PDF looks to me to be the one you need for the 8 wire steppers; just double check the ref number as similar stepper don’t always have the same colour code. Where did you get the attached pic of the 6 wire? John |
#12
http://www.silmanet.com/dk/catalogue...roduct_id=4860 One more question (Honest!), what should I set the Rev/unit setting on the driver to, it starts at 400 and goes upto 25000! On my current 1nm motor I use a setting of 80 in mach2 with a 5mm screw equals 400 per rev..... Also found another drawing that looks definitely like the right part..... Andy Last edited by Normsthename; 12-15-2006 at 05:15 PM. |
