I pulled this out of an old flatbed scanner. In case the label doesn't show up, it says: STH-39D1126 1.8 Deg/Step 4.1 Ohm The power supply from the scanner says: Output for motor 10V 0.4A Is this the voltage needed for the stepper? Too bad I tore up the power supply. Will this have enough torque to turn any of the axis? How would I go about testing it? I've also got a pen plotter that should have some steppers in it, will they likely be able to run a mill? Thanks *EDIT: Sorry about the large image files. Here's some smaller ones. ![]() ![]() Last edited by tobybirch007; 12-11-2006 at 07:01 AM. |
| The only thing I've been able to find on it is "No information found." Torque was a worry of mine since all it did was move a scanner bulb and imager back and forth. I am however planning a small, say 12" x 18" mill, and i want to machine foam or plaster with it. But, if it's all it can run, I wouldn't mind a PCB mill either. Thanks for the help |
| you could use these motors to make a really small guy but it will not have much power. It could be an economical learning tool but probably won't satisfy your demands. Some decently sized motors are not terribly expensive and will give you a much better machine. Matt |
#11
| This is just my opinion but I would say no; but this will depend on how fine you wish to mill the traces. It may be worth your while reading through this and maybe asking your question there. http://www.cnczone.com/forums/showthread.php?t=23363 Also this thread http://www.cnczone.com/forums/showthread.php?t=19362 for stepper motor and drives from plotters. John |
#12
