I have {4} Applied Motion steppers. Part # 5034-350. 8 wires. 2.47V 5.9Amp.
I know NOTHING about how to test these to see if they will move the shaft. The wires are color coded Black - Red - Orange -Yellow - White/Orange stripe - White/Red stripe - White/Yellow stripe - White/black stripe.
My question is can I hook up a 12V DC power supply to test these motors for rotation? And if I can, in what sequence should the wires be hooked up? Such as black & White/black together? and so on. Any help would be greatly appreciated.
I do not have any Gecko drivers yet, just the motors and a 12V DC power source.
No....they are steppers and require that the coils be energized in a particular sequence. While you're waiting for a Gecko, Xylotex, etc.....get yourself a 40 or 50 VDC supply.
This brings up a question I have been thinking on. What would it take to run a stepper in a chosen direction at a speed chosen by a trim pot ??. I some folks talking about fpga motion control, and have been reading on that. It seems to me that a stepper, a Gecko, a trim pot, and some mounting brackets, limit switches, etc. would make an X axis power feed. many of the parts used could later be used for a full on cnc conversion. Couple that with a DOS or LINUX based DRO program to use an encoder on the motor and it could have some real utility. I know you can buy harbor freight power feeds for $150 i saw in another post, but this would be better than that I would think. The only slight PITA in the deal would be that when you moved it by hand it would be disconnected like a power feed is...but when you have a power feed you really don't move things by hand that much, or very far :-)
Yes....you could debounce the step and direction pins to the gecko....the thing is....without computer control.....you are only going to succeed in going CW or CCW for some time....
A 'trimpot' alone wouldn't be enough. You need to produce digital pulses at a particular rate and input them to the Gecko to advance the axis. You could design a circuit to do this of course (the circuit might be one IC and a few other components plus power supply etc), but getting a computer to do it is probably easier in some ways - but then you essentially have a cnc machine. I did see somewhere a 3 axis controller that had a joystick input so it could work stand alone without a computer.
Well My point was that a servo power feed is a pricey item :-). And a setup like I desribed would work nice as a power feed. I sort of understand what the Gecko or other driver needs to do it's job, what I was asking is how one would generate the pulses, and how one would vary their timing to control speed :-).
