Old 01-31-2004, 08:11 AM
turmite is on a distinguished road
Question encoders with steppers
I know that most all stepper systems are open loop, but I have a question I need answered. If you installed encoders on the back of steppers like in servo systems, and used the glass scale abs positioning encoders can you make a closed loop system out of steppers? Ok maybe more than one question. When using servos with the rotary encoders only, don't you just have a more powerful open loop system? I know the Gecko drivers will fault if the system gets so many steps out but does it just shut off or does it actually try to gain or lose steps to correct?
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 01-31-2004, 09:06 AM
balsaman's Avatar
balsaman is on a distinguished road
With gecko servo drives it's closed loop back to the drive, but not the controller (computer). It will not make any corrections. The gecko will allow a 128 step error as it tries to follow the stream of pulses from the computer, if it goes beyond the 128 step error, it quits. The nice thing about it is if it can't get there, you will know about it, and the gecko can let the controller know about it too. The part may be toast but you know it right away.
With steppers, you may be loosing steps, but won't know it till after you are done running the 3 hour gcode and measure it.
Eric
I wish it wouldn't crash.
Old 01-31-2004, 08:44 PM
Thanks Eric.
Mike
Can I use Steppers with linear/glass encoders? lukesdaddy Mach Software (ArtSoft software) 9 04-13-2005 01:14 PM
steppers with encoders miljnor Stepper Motors and Drives 4 02-03-2005 09:44 AM
Servos, steppers, drives and encoders, Oh my MobilDave Servo Motors and Drives 1 09-10-2004 07:04 AM
Choosing Steppers RXTurbo General Metal Working Machines 3 06-17-2004 11:21 PM
steppers and current ullbergm General Electronics Discussion 0 01-29-2004 03:24 PM
