Old 12-03-2006, 12:07 AM
ged ged is offline
ged is on a distinguished road
500oz math
Could someone please check my math for a power supply.
nema 23 500oz rex steppers,3 volt,3 amp\phase
I figured I would need 68 volt dc 48 volt secondary
6 amps 120VA
10,000uf CAP 50volt
rectifier @25 amp 50 volt
thanks for any replies Ged
Old 12-03-2006, 09:17 AM
ged ged is offline
sorry but I forgot to mention that I will be using Gecko drives.
Old 12-03-2006, 09:25 AM
Al_The_Man's Avatar
If the 6 amps is for 100% duty cycle, I make that just over 500va or 340va for 60% duty, a 5500µfd min. capacitor for 5% ripple.
If your DC is 68 volts your bridge will need to be higher than 50v? The cost is minimal for higher voltage, go with 100v or 150vdc PIV.
Old 12-03-2006, 10:03 AM
ged ged is offline
Hi Al thanks for your reply I have 3 steppers at 3v 3a\phase
According to Mariss`s paper I figured 67% of 9amps is 6.03amps
this is how I came up with 120va. Did I do something wrong? the motors are two phase 4 wire. Would that be 6amps for ea motor?
Old 12-03-2006, 10:40 AM
Al_The_Man's Avatar
You can base the the required VA or power rating on your estimated average current draw (6amps) x 48v = minimum 300va.
Old 12-03-2006, 10:51 AM
ged ged is offline
thank you Al you ARE the man!
