Old 01-30-2004, 12:00 PM
Jcadwell is on a distinguished road
Power Supply Size
Any reccomendations for power supply use with HomeCNCs servo motors? I want a supply that will power 4 using Gecko 320s, and be 36 volts or so. What kind of amperage do I need? Thanks.
Old 01-30-2004, 12:14 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
I am telling everyone to build a 36VDC supply @ 20-25 amps.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 01-30-2004, 01:28 PM
Excellent, I'll design one up then. Thanks.
Old 02-05-2004, 06:32 PM
thuffner3's Avatar
Gold Member
thuffner3 is on a distinguished road
May I see the design when you get it drawn? Just Newbie interest.
Old 02-05-2004, 07:38 PM
ljoe1969 is on a distinguished road
i would like to see that also.
Old 02-05-2004, 10:19 PM
Sure, I'll have to get on it then. I'm looking around at Iron to see what I can come up with that isn't unaffordable. What cost bracket is desirable? Getting it under 150 isn't too hard, getting under 50 requires more creativity.
Old 02-25-2004, 03:52 AM
Patrick2by4's Avatar
Gold Member
Patrick2by4 is on a distinguished road
could you also list the websites (or vendor ) where you got the parts
-thanks
-Patrick
_____________________________________________
measure twice, cut once - a good rule for everything
Old 02-25-2004, 08:28 AM
owhite is on a distinguished road
I recently put together a power supply using this schematic:
http://www.plitron.com/pages/technote.htm
See the "Full Wave Bridge"
I went about the design process using this terrific tutorial:
http://nilno.com/laser_dir/power_supply_design.pdf
which was written by this guy:
http://www.campbelldesigns.com/
Here is a longer discussion of how I designed my power supply:
http://www.nilno.com/laser_dir/archi...1_archive.html
and a thread on cnczone when I had a problem with the toroidal transformer producing too much voltage that was repaired quite elegantly:
http://cnczone.com/showthread.php?s=&threadid=2924
Almost all parts were purchased on ebay, except the toroidal power transformer which I got here: www.plitron.com. For power supplies of the size 36vdc @20 amps, you probably dont need a toroid, you may be able to go with transformers like at these sites:
http://www.angela.com/catalog/transf...nsformers.html
http://www.hosfelt.com/
http://www.mouser.com/
Building is fun but dont forget that if you search on "power supply VDC" at ebay you may get exactly what you need already put into an enclosure with all the right fuses and switches etc. Many other search terms will also work.
Owen
Old 02-25-2004, 08:44 AM
who's in favor of a "things to know when you're making a power supply" FAQ?
Old 02-25-2004, 09:44 AM
Al_The_Man's Avatar
A couple of points on transformers, the toroid type although usually more expensive is more efficient due to the magnetic field contained with in the transformer itself and not radiated out as with an E/I core type. Therefore it is usually smaller and takes up less space. The other advantage is with a toroid it is easier to either modify a winding as in the CNCzone link Owen has shown. or if you require a separate 5v winding for logic etc, you can wind another secondary, which for 5v would be around 15 to 20 turns. Use enamel wire (used to be known as magnet wire). The gauge would depend on the current drawn. You would also have to watch you do not exceed the total V/A rating of the transformer.
Al
Old 02-25-2004, 04:27 PM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
I made this last night because I have always wanted to show visually what happens in a power supply. I could have more details but settled for this. It is debated if electrons flow from positive to negative or the other way around, so please have mercy on me if you dont like my diagram
Old 02-25-2004, 08:58 PM
Al_The_Man's Avatar
I think you got it right, but I don't think electron flow is actually debated anymore, The old tube technology actually demonstrated that electrons flow from negative to positive, but we still tend to use 'conventional flow' (pos to neg) rather than electron flow when we are using a demonstration.
Al
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 09:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 03:47 PM
5 Volt Power Supply Tripping murphy625 General Electronics Discussion 13 02-27-2005 09:05 PM
Is this power supply rating adequate? jerryrigge General Electronics Discussion 3 11-25-2004 10:06 AM
Choosing a Power Supply for Retrofit? pfeist General Metal Working Machines 4 05-23-2004 10:36 PM
